Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: $2 insert coin button for icade/bartop  (Read 1994 times)
thebrokenjoystick
  • Last login:December 01, 2018, 08:23:18 pm
  • The cake is a lie
    • My Vogon Poetry
« on: September 29, 2018, 05:52:58 pm »
I liked the placement of the insert coin on the icade so wanted to make it "real".  Here's my solution. a $2 lighted rectangular button, some graphics printed out, and some icade modifications (Dremel!). I still have to go to the dollar store to find something with a 5V LED to put in, instead of the 12v one that came with it.
« Last Edit: September 29, 2018, 05:57:22 pm by thebrokenjoystick »
  • Last login:Today at 10:26:21 am
Re: $2 insert coin button for icade/bartop
« Reply #1 on: September 29, 2018, 06:20:29 pm »
Before you do, try running the 12v LED on 5v.
Con:
- May be slightly less bright, but you may not even notice   :dunno
Pros:
- Lower current draw
- Longer LED life
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #2 on: October 01, 2018, 02:33:18 pm »
I did - nothing.
  • Last login:Today at 10:23:59 am
« Reply #3 on: October 01, 2018, 02:57:14 pm »
It's probably either a #555 or #44/47 style bulb.  Grab one intended for a pinball machine and you're good to go.
This forum needs more threads about Arcade 1Up cabinets.
« Reply #4 on: October 01, 2018, 03:15:39 pm »
I did - nothing.
That's odd.   :dizzy:
All of the 12v LEDs I've tried work great on 5v.
Any chance that you accidently reverse-biased the LED? (i.e. 5v and ground swapped)
The #555 LED bulb from Paradise Arcade works on 5v.  #44 or #47 LED bulbs should work, too.
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #5 on: October 04, 2018, 08:56:00 pm »
Thanks for the advice... tried again tonight and switched + and - and it works with 5V! I swear i tried that. Thanks!
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #6 on: October 04, 2018, 11:41:33 pm »
Wow - maybe everyone already knew this, but on the "Zero Delay Arcade USB Encoder", on mine there are two unmarked red connectors - those output 5V. You can use one of the extra wire with connectors they gave you, plug it in there and get 5V. I used that to power the LED on the insert coin button! If anyone wants pics of what I mean, let me know.
« Reply #7 on: October 05, 2018, 12:07:51 am »
Glad to assist.   :cheers:
Related thread here.
thebrokenjoystick
  • The cake is a lie
    • My Vogon Poetry
« Reply #8 on: October 08, 2018, 11:06:46 am »
Ah - ok, so it is already known. I thought I stumbled on something cool. Well, ti IS cool, just already known :)
ballboff
  • Last login:April 10, 2020, 03:32:22 pm
« Reply #9 on: October 24, 2018, 03:33:09 am »
This is brilliant.  I'd never thought of doing this,  mine just lights up!  This frees up another button, which is critical when you've already got a limited number of buttons to play with.  The coin button I had set up before could be used for something else like entering the setup menu for instance.  Looks the part too!
