Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Microswitch problem?  (Read 366 times)
Fonkybeachbum
  • Last login:May 18, 2019, 10:28:04 pm
« on: June 06, 2018, 12:28:40 pm »
Hello, I have a cheaper flight stick in a control panel.  When going right,  I can hear the switch engage, but the right direction will only work if I wiggle the stick to just the perfect position.  All of the wiggling is done in the area where the throw has already engaged the switch, but the right will only work if it's just in the perfect spot.  Any ideas on why this is happening?  Thanks.
Titchgamer
  • Online Online
  • Last login:Today at 06:49:24 pm
Re: Microswitch problem?
« Reply #1 on: June 06, 2018, 12:30:03 pm »
Faulty microswitch, Just replace it.
