Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: N00bs Guide to LEDBlinky  (Read 1118 times)
vaderag
  • Last login:Today at 05:36:20 pm
  • Building my own cab :)
« on: June 03, 2018, 04:45:07 am »
I imagine this might exist somewhere, but sure am failing to find it...
I have LED buttons on my CP and my goal is to get the relevant buttons lighting up for each game in MAME
Is there an easy (ish) way to do this without going through every game independently??
  • Last login:Today at 08:37:54 pm
  • Bitches love Centipede
Re: N00bs Guide to LEDBlinky
« Reply #1 on: June 03, 2018, 12:41:49 pm »
I have a custom colors.ini you can try if you'd like.
« Last Edit: June 03, 2018, 12:43:28 pm by Nephasth »
%Bartop
vaderag
« Reply #2 on: June 03, 2018, 01:30:46 pm »
That would be great!
What MAME version is it?
Sent from my Mi A1 using Tapatalk
« Reply #3 on: June 03, 2018, 02:43:20 pm »
Not sure that mame version matters? PM me your email address and I'll send it and a controls.ini file for you to try out.
%Bartop
vaderag
« Reply #4 on: June 03, 2018, 02:58:51 pm »
Pm sent
I only wondered about MAME version as ROM names change occasionally depending on version...
luizw81
  • Last login:Yesterday at 10:32:16 pm
  • I love the Power Glove. It's so bad.
« Reply #5 on: June 03, 2018, 06:04:30 pm »
Hey Nephasth.  Would you send that to me also?  I got a LEDBlinky I'm looking to add to my cab when i get the gumption to tackle it.
Sent from my SM-J320R4 using Tapatalk
« Reply #6 on: June 03, 2018, 08:04:15 pm »
Once you get the gumption and start tackling it, hit me up.
%Bartop
rave0035
  • Last login:Today at 12:57:14 pm
« Reply #7 on: June 04, 2018, 08:05:54 am »
Just did this on my first machine.  I found the readily available colors.ini worked for about 80% of the games I've got on my machine - the rest I'm going game by game on to tweak.  It's exhausting but it will be worth it in the end (note: my cab doesn't host thousands of MAME games... would not be do-able if I had more than 40 or so to tweak).
The trouble is, many of those that I'm finding not in colors.ini are because they were generally franken-cabinets or a pic of their CP is non-existent on the Internets (i.e. Martial Masters).  I'm just getting creative once I hit a dead-end :)
Mike
vaderag
« Reply #8 on: June 04, 2018, 08:51:51 am »
Mike
Nice - when you say 'readily available' - is that different to the ones shared above?
« Reply #9 on: June 04, 2018, 09:30:53 am »
The ones I shared were modified versions of the readily available ones. Fixed colors in some games, and if I remember right, I had to fix all the NeoGeo games.
%Bartop
arzoo
  • Last login:Today at 04:28:32 pm
  • We are not in the 8th dimension. We are over NJ.
    • LEDBlinky
« Reply #10 on: June 05, 2018, 08:31:30 am »
If anyone wishes to provide an updated version of the colors.ini file, I'm more than happy to include it with the LEDBlinky distribution.
Robots will kill you.
Arcade Addiction
vaderag
« Reply #11 on: June 08, 2018, 07:56:15 am »
So I've tried the colours.ini and it worked. Briefly.
Somewhere in my setting up I've broken it.
Tried to MAME test and I get the start and exit events.
Rocket launcher has correct paths and the led blinky UI has the right paths for mame and the colours etc
If I try load the troubleshooter and follow the instructions I get no change in the message
Input maps are set correctly
If I try load the controls editor however I get an error saying I need to set the input map, but loading still has everything set and I've tried changing and resaving just to kick it in.
Any idea what's going on??
vaderag
« Reply #12 on: June 08, 2018, 09:42:29 am »
So, interestingly, contrary to most things I've read on the web I can only get this to work if I a) enable HyperHQ to use LEDBlinky and b) launch the game via Hyperspin.
I'm using Rocket Launcher, which also has the LED Blinky path setup and told to use it, but launching direct via RocketLauncher does not seem to do anything
One aditional issue I am having however is that despite the relevant values set in Colors.ini, my coin/P1/p2 buttons do not light...
My pause button lights per the default set in the controls setup, but I can't find the relevant button there to light my exit button either...
EDIT: Just to confirm, I'm pretty certain that nothing from RocketLauncher is actually being used - for example I have a second duplicate of a mame system in Hyperspin and RL, I have told RL to system name as MAME but it doesnt - looking at the unknown games list it's getting the original system name
« Last Edit: June 08, 2018, 10:25:29 am by vaderag »
vaderag
« Reply #13 on: June 09, 2018, 05:37:41 am »
So I still need some help...
I have mostly got things working. HS and RL on the whole don't play nicely together, seems I can use either one or the other (RL only seems to work if I load LED Blinky at start, not sure how to get Hyperspin specific lighting that way tho at startup - only goes that way once I've loaded and exited a game)
But the issue I really want help with is thus..
I have default LEDs set for MAME and every LED works as expected EXCEPT the exit button.
This is set as common -> UI_CANCEL (which is the same as my global RL exit button), but doesn't light...
I can't seem to find a generic EXIT option in the controls editor.
Anyone able to help me get this lit?
NB. Works fine in all tests and animation, there is no issue with the leds
vaderag
« Reply #14 on: June 12, 2018, 11:32:52 am »
Still having this issue...
Anyone?!
