Author Topic: Outrun 2006 - Fixed Sun and Bloom effect  (Read 15324 times)
italospain
  • Last login:September 26, 2022, 12:10:19 pm
« on: May 19, 2018, 05:28:00 am »
copy from Media folder inside Outrun Coast to Coast the File lens_flare_offset.bin into the Common folder.
greetings
nugarp
  • Last login:February 22, 2026, 08:15:13 pm
Re: Outrun 2006 - Fixed Sun and Bloom effect
« Reply #1 on: May 19, 2018, 04:57:39 pm »
Are you saying this fixes the teknoparrot version or pc version? Didnt realize there was an issue with the PC version.
Sent from my SM-G950U using Tapatalk
Boomslang
  • Last login:January 01, 2024, 08:20:43 pm
« Reply #2 on: May 19, 2018, 05:54:42 pm »
I've already got a fix for teknoparrot version @ 1080p
But yea pc version is fine already I thought
« Last Edit: May 19, 2018, 06:10:27 pm by Boomslang »
italospain
« Reply #3 on: May 20, 2018, 04:59:27 am »
it is for the pc version. The sun and lens flare effects are missing for the Outrun 2 SP tracks. And this is the fix.
isamu
  • Last login:February 19, 2026, 01:09:24 pm
« Reply #4 on: May 20, 2018, 12:13:40 pm »
Boomslang....I have the Resolution Patcher as well as the Shadow Fix patch. I applied the resolution patcher at 1920x1080. How do you fix the bloom and sun effect in the TeknoParrot version of ORS2SPDLX? When the sun comes out it just whites out nearly the whole screen.
MrThunderwing
  • Last login:February 21, 2026, 03:10:59 pm
  • As I pass, do I give you the ass or the crotch?
« Reply #5 on: May 20, 2018, 02:16:59 pm »
Ha! Awesome discovery. The lack of bloom has always been one of my biggest bugbears with the PC version of Outrun 2006 and it turns out they were in there the whole time! Man, Sumo may have knocked it out of the park with the console versions, but they seriously fumbled the ball with the PC port. So between Howard's FXT mod sorting the controls and FFB out and the bloom effects getting added back in, the PC version should be the best version now.
« Last Edit: September 01, 2018, 09:07:31 pm by MrThunderwing »
italospain
« Reply #6 on: May 20, 2018, 02:32:39 pm »
it looks like the draw distance is better in the PS3 and X360 Version( most obvious first Beach Track from Outrun 2 SP Sailor Ships pop ins) even the Lindbergh version has the problem.
MrThunderwing
« Reply #7 on: May 20, 2018, 04:13:05 pm »
Actually, it still doesn't look quite as nice as Outrun Online Arcade. Although the Bloom is now noticeable in the PC version in the bits where the sun is in the background, the bloom effect is immediately noticeable as soon as you start the stage (using the Legend stage as an example) in the PS3 version, whereas it still looks a bit drab on PC.
Boomslang
« Reply #8 on: May 21, 2018, 12:33:59 am »
Nice work on finding this!
VirtuaIceMan
  • Last login:September 09, 2025, 07:52:27 am
« Reply #9 on: May 23, 2018, 06:45:30 am »
That's brilliant, I always thought it was just not there, not that it was simply an asset in the wrong folder!
Now, if there's any way to get the end animations (volcano, shuttle lift-off, etc) working, then that'd be amazing. I remember chap from Sumo saying they were big videos overlaid into the game; they were added to the PS2 Japanese port, not sure about others (presumably Outrun Online Arcade has them).
Check out my racing game videos, including every PC F1 and Rally game ever, over here: https://www.youtube.com/user/VirtuaIceMan/
MrThunderwing
« Reply #10 on: May 23, 2018, 11:34:18 am »
It does, although they lack sound effects for some reason.
