Lightguns --- Bug Reports --- Site News
Author Topic: PC to CRT TV with CRT Emudriver  (Read 878 times)
imtrashed
  • Last login:November 02, 2018, 01:39:56 pm
« on: February 16, 2018, 03:45:26 pm »
I plan to begin setting up a new PC to CRT TV via  Radeon card with CRT Emudriver installed.  I plan to run it through a VGA to Component Transcoder so that I can connect the card to the component inputs on the TV.  I'm confident I can get this all working since I was able to set up CRT Emudriver with the same card to an arcade monitor, but that was running through a Jpac.  Should I be concerned about the signal before Windows loads?  It's a fast enough PC and the OS will be on a SSD, so it boots pretty quickly.  Wondering if I have to go the Atom 15 route or if I should be OK.  Any thoughts?
buttersoft
  • Last login:March 20, 2019, 01:18:37 am
  • Is running at 15kHz
Re: PC to CRT TV with CRT Emudriver
« Reply #1 on: February 18, 2018, 08:17:42 pm »
It's not good to stress your monitor that way. Atom15 has worked for me with 4 different cards through ATIwinflash. Search the GroovyMAME subforum for your particular card and find out if people are having problems. And remember that a mobility card or APU might be problematic if it's even possible.
« Last Edit: February 18, 2018, 08:22:44 pm by buttersoft »
