Site News
Author Topic: Touchups  (Read 1208 times)
pixel
Touchups
« on: November 15, 2017, 02:14:31 pm »
 Hello All
 When I was in the Pinball restoration hobby... I was told that using Enamels would not be good,  if you wanted to use Automotive clearcoat... as the clearcoat would cause them to lift / dissolve.
 I thus then went into fixing areas with acrylics.  Problem with them... is that they are often dull / matt.. do not easily mix/blend... and matching certain colors can be a bit tricky to boot.   Flow can be erratic... making fine lines a real challenge.
 Then I heard an even worse quip...  that if you mix too much water into your Acrylics... the binder will be too weak... and in a few years,  it will crack, lift, and peel.   Ive seen cracking from heat + old lacquer / clear under inserts... and its not very nice looking...   so if thats any indication,  its best to avoid that potential.
 Then I heard about Acrylic additives,  that you mix into them,  to give them unique properties... such as:
 - Smoother Flow
 - Translucency
 - Matt or Gloss Shine
 - Longer Dry times
 - Ability to mix/blend with other colors already on the canvas  (for a certain amount of time).
 Ive yet to test these yet.
« Last Edit: April 10, 2018, 10:53:57 am by pixel »
Sitemap 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
