Author Topic: Trackball and spinner dont work in GM .181 for me upgraded from .161  (Read 2249 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
I can't get my Spinner and trackball to register in GM when I try to set my controls. I upgraded from .161 to .181 to see if my LEDblinky would work better and also have a more robust system. They worked fine in .161 for me. I put my mame.ini in my /ini folder I thought maybe that was the problem. My settings are almost exactly the same as my .161 .ini but no trackball or spinner. Any help? Thanks
  • Last login:Today at 12:13:02 am
Re: Trackball and spinner dont work in GM .181 for me upgraded from .161
« Reply #1 on: November 13, 2017, 01:56:57 pm »
This looks like a good place to start.
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
If you're using a GUI version of MAME (MAMEUIFX, etc.) there should be a pulldown in the User Interface to set the device control types.
   or
You can change the items in red to "mouse" -- you may also need to delete/redo config files for individual games that override these settings.
Vincefaro
« Reply #2 on: November 13, 2017, 03:54:33 pm »
Huh, I tried fooling with those settings . I did not get any results. It's weird my .161 version had those same settings no mouse setting except for mouse_device.
Calamity
  • Moderator
  • Last login:Yesterday at 04:52:46 pm
  • Quote me with care
« Reply #3 on: November 13, 2017, 04:01:37 pm »
You may try playing with the -mouseprovider option. Check this: http://docs.mamedev.org/_files/MAME.pdf
Steps to create a log:
Vincefaro
« Reply #4 on: November 15, 2017, 02:06:55 pm »
So I tried all of the different settings and I still could not get it to work. I decided to do a new version of GM .179 and I installed it , upgraded my .161 roms and used the same settings as my .161  mame.ini and IT Works!
