Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: Joining frame together.. questions  (Read 2006 times)
WetpantsMcGee
  • Last login:July 28, 2019, 03:44:18 pm
« on: September 08, 2017, 05:52:58 pm »
Hey guys,
Currently underway with my first cabinet build.  I've got the sides ready to go, now I need to frame up the bottom/top/back pieces and get them together.  I want to use something stronger than wood screws, what do you guys suggest?  I want this thing to be pretty solid.
-WetpantsMcGee (Dan)
lilshawn
  • Last login:Today at 05:50:07 pm
Re: Joining frame together.. questions
« Reply #1 on: September 08, 2017, 06:00:13 pm »
PL premium 3x.
http://www.loctiteproducts.com/p/pl_ca_prem/overview/Loctite-PL-Premium-Polyurethane-Construction-Adhesive.htm
don't opt for the extra strength 8x or whatever... it's too thick.
the screws basically just hold it together until the PL dries. you'll wreck it trying to break it apart.
apply bead towards the inside of the cabinet so you don't get any squeeze out. wipe up any mess right away cause once it's dry, the only way to get rid of it is to cut/scrape it off.
WetpantsMcGee
« Reply #2 on: September 08, 2017, 06:57:26 pm »
PL premium 3x.
Thanks!  I'll go grab a tube.  I better hurry though, my local Home Depot only has 204 in stock.
lilshawn
« Reply #3 on: September 10, 2017, 09:51:20 pm »
Of course, that's because when I need 20 tubes of landscape block adhesive, they have 12 tubes...spread over 4 stores.
WetpantsMcGee
« Reply #4 on: September 11, 2017, 12:30:37 pm »
 :lol That's usually how it works; guess I got lucky.
Is it better to use when I screw the pieces in, or can I just run it along the seam after I've put stuff together?
lilshawn
« Reply #5 on: September 11, 2017, 02:00:59 pm »
before for sure... right on the inside edge. you aren't worried about sealing stuff in or out of the cabinet (which is all a bead would do) you want it to glue the pieces together. the glue does the holding.
I make cocktail cabinets for sale locally, and PL and a staple gun is all I use. the staples basically hold things together while the PL dries. in all honesty, you could just clamp it and not even nail, staple, screw or whatever and it would still be just as strong.
i use the PL to glue 3/4"x3/4"x8" wood battens on the edge of one of the pieces. (staple them down) and then let them set up... then attach whatever to that piece stapling through the battens in the other direction... nothing from the outside is visible. When I first started out, I screwed them down after gluing them with PL and found it not really necessary.
