Lightguns --- Bug Reports --- Site News
Author Topic: Aimtrak not working with PS2  (Read 1815 times)
Kirkanos
  • Last login:August 03, 2017, 02:57:32 pm
  • I want to build my own arcade!
« on: July 19, 2017, 10:47:44 am »
I have an Aimtrak Lightgun without recoil and am trying to get it to work with a PS2 but it does not.
I have read through the setup guide and the PS2 guide but to no avail.
When I first tried it I could get into calibration mode by holding the the 2 buttons when turning the PS2 on but I couldn't do anything once I was there. I never saw any cursor and even though I could shoot (the screen flashed and I got a shooting sound), I couldn't do anything else.
I did manage to start Time Crisis II with the gun and it seemed that I could shoot things but only if I only made minute gun movements. The reload also worked when I moved the gun away from the screen.
I eventually found that the sensor was not working as the connector that connects to the sensor PCB was not fully connected. When using a mobile phone camera, I could not see the LEDs.
Once I pushed the connector on more securely the phone camera picked up the LEDs without any problems and continues to detect the sensors as being on/active.
I plugged it all back into the PS2 and again I could start calibration mode by holding the 2 buttons but again I could not see a cursor! I unplugged and re-plugged and since then I cannot even get into calibration mode. Nothing happens when I press the buttons.
Notes
The gun works perfectly on a PC. I can move the cursor and I can select items by pressing the trigger or if I configure the buttons I can use these to select.
Using the Aimtrak v2.0 config utility on my PC:
  • SENSOR VIEW CHECK works (although the red dot moves in the opposite direction to gun i.e. left is right and up is down)
  • SHOW DATA works. I can see the X and Y coordinates etc changing. Nothing appears in the Cal Status field
  • Firmware: 9.19
  • The gun is set for ID:1
  • Calibrate works
  • Button Assignments (changed numerous times), On and Off screen configs being the same and set as
    • TRIG: Mouse Left
    • LEFT: GP Button 1 with Enable Cal set
    • RIGHT: GP Button 2 with Enable Cal set
  • Tilt / Z Correction: Continuous
  • Recoil: 2.5 (the gun does not have recoil)
  • IR Gain: 4
  • Disable Auto Gain: Checked
  • Cal Delay (Secs): 5
  • Emulate Mouse
As mentioned above, these are the current settings. I have changed all them to different settings previously.
I have also tested using both Time Crisis II and III and tested on both a Slim and Fat PS2.
Titchgamer
  • Last login:Today at 05:31:18 pm
Re: Aimtrak not working with PS2
« Reply #1 on: July 19, 2017, 02:46:25 pm »
I have never used mine with a PS2 so cant really help much sorry!
Your best bet will probably be to contact Andy at Ultimarc directly and hopefully he can help you out.
ark_ader
  • I glow in the dark.
« Reply #2 on: July 20, 2017, 01:53:56 am »
A good reason to skip Ultimarc.  Nothing but problems lately.  ::)
Titchgamer
« Reply #3 on: July 20, 2017, 03:49:32 am »
What problems would they be the Ark?
ark_ader
« Reply #4 on: July 20, 2017, 01:50:34 pm »
Oh boy! Where to start?
Titchgamer
« Reply #5 on: July 20, 2017, 01:55:58 pm »
The beginning is usually a good starting point.
Kirkanos
« Reply #6 on: August 03, 2017, 02:49:03 pm »
I'm thinking that based on further investigations my Aimtrak issue might be down to upgrading to the latest firmware: 9.19.
Before I upgraded I was on 1.3 but this just confuses the hell out of me when I now read (must have been a bit too eager to do the upgrade to read this note), that you shouldn't upgrade to a version with a different first digit!
I could only find one upgrade version though so I used that. It just happened to be 9.19.
How do I rollback or even find the latest 1.xx firmware version?
Also, the PS2 setup guide states that the games were tested with version 8.11 but the *IMPORTANT* note seems to suggest that I can therefore never reach this 'zenith' of a firmware version.
I noticed another poster had the same question and their problem got resolved but they never gave any hint on how. Again, rather frustrating.
I have emailed Andy @ Ultimark but if anyone can point me to a fix in the meantime, it would be much appreciated.
