Author Topic: Couple questions  (Read 1011 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
Couple questions
« on: January 26, 2004, 08:41:01 am »
Greetings,
My control panel is all wired up and I was testing it out. I plugged my puter into my tv and POOF, 27 inch windows!
Question #1 - Any way to make windows readable on my tv? I cant read any of the text. I am at 800x600. Yes my video card supports tv and the settings are correct.
Question #2 - Some of the vertical games work great on the tv. Some dont. Is there a setting or something that will correct that?
Question #3 - Can I use the Microsoft Sidewinder Steering wheel and pedals with Mame? http://www.microsoft.com/hardware/sidewinder/PrecPro.asp
Re:Couple questions
« Reply #1 on: January 26, 2004, 08:52:28 am »
#1 Use 640x480 and/or enlarge your font size(s)
#2 Use ini files to specify resolutions to use eg 'resolution 640x480'
#3 Yes, make sure you have 'joystick 1' set in your mame.ini
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
Re:Couple questions
« Reply #2 on: January 26, 2004, 09:08:06 am »
if you use MAME32 you can set the resolution lower in the display menu for all games
"Owens is the ringleader in the ass hat circus"  D K
