Author Topic: Unable to change controller ID on i-pac ultimate I/O board  (Read 1865 times)
xantari
  • Last login:January 16, 2021, 06:55:05 pm
  • Browsing aroud!
« on: February 18, 2017, 12:11:02 pm »
All,
Has anyone successfully changed the controller ID on an i-pac ultimate I/O board from ultimarc?
I'm using the Pacled64 tool. I pick device 2, click Set controller id 2 then press the OK button, but nothing happens.
I go back to LEDBlinky control editor and it still wants to make my ultimate I/O board controller ID 1, which is the same ID as my Pacled64 board.
Scotty_C
  • Last login:December 28, 2024, 08:40:26 am
  • The addiction is strong!!
Re: Unable to change controller ID on i-pac ultimate I/O board
« Reply #1 on: February 19, 2017, 01:20:03 pm »
You can't change it. You'll need to email ultimarc to get specific firmware if you want to run 2+ UIO's on a system.
Best bet would be to change the standalone PACLED64 board to another ID.
« Last Edit: February 19, 2017, 01:21:42 pm by Scotty_C »
Ginsonic
  • Last login:June 12, 2025, 02:12:31 am
  • Arcade enthusiast !
« Reply #2 on: February 20, 2017, 11:33:11 am »
For LedBlinky it is definitely no problem to operate two different devices like the UltimateIO and the PacLed64 together with the same ID, only two equal devices would exclude each other ! In my Vpin I currently have one UltimateIO (ID 1) and two PacLed64 (ID 1 and 2).
And Scotty_C is right, for operating two UltimatIO devices together, you need a special firmware from Ultimarc.
