Author Topic: PACLED 64 giving me trouble  (Read 1351 times)
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« on: February 15, 2017, 05:43:00 am »
I have three PacLed64 boards in my cab, and once in a while the third one won't turn on. I notice it because half my board is unlit. The only fix is to unplug the power and replug it in. If I unplug the whole cab, then back on, it works. Usually I leave the cab plugged in, so it's kind of an annoyance. Is my PACLED going dead?
lowlytech
  • Last login:February 07, 2019, 08:12:12 am
Re: PACLED 64 giving me trouble
« Reply #1 on: February 15, 2017, 08:38:26 am »
Might try a different USB cable or USB port on your host system?  Other than that, maybe something is awry with the controller.
Edit.. Are your controllers plugged straight into system ports or are you using a USB hub??
« Last Edit: February 15, 2017, 08:48:53 am by lowlytech »
MydknyteStyrm
  • Makeup FX Gamer
« Reply #2 on: February 17, 2017, 11:21:55 am »
I changed the USB plug into another port and it seems to be fine now. It's looking like my USB hub is failing as far as power management
