Lightguns --- Bug Reports --- Site News
Author Topic: Custom 4 Player Arcade Cabinet (Dark TMNT Theme)  (Read 11117 times)
Niels Arcade
  • Last login:May 01, 2018, 05:35:06 am
  • I built a Star Wars themed arcade cabinet
    • forum.arcadecontrols.com/index.php/topic,147851.0.html
Re: Custom 4 Player Arcade Cabinet (Dark TMNT Theme)
« Reply #80 on: November 21, 2017, 05:40:19 am »
Does anyone have any recommendations on where to buy a marquee light? Thanks
For my Star Wars cab I used a cheap warm white LED strip I bought at a local store for about 15$. To spread the light I used aluminum foil. The LED strip came with a simple IR remote control dimmer so I can make it as bright or dimmed as I want it to be. I put the IR receiver behind the Marquee plexi with artwork (top left corner in the picture) and if I point the remote within a meter (3 feet) distance it works perfectly.
« Last Edit: November 21, 2017, 05:46:57 am by Niels Arcade »
http://forum.arcadecontrols.com/index.php/topic,147851.0.html
dgrace
  • Last login:Yesterday at 09:22:26 am
« Reply #81 on: November 26, 2017, 07:07:32 pm »
Thanks man.  I like your idea.  Very creative
dgrace
« Reply #82 on: November 26, 2017, 07:13:44 pm »
Finally starting to put this thing together.  Hopefully going back to bro-in-law's on Tues to continue connecting this bad boy.  Trying to get the box finished before winter really hits here in Idaho.  Gonna be harder to cut outside in the snow:).  Then all I have left to do is paint, graphics, electrical, wire management, etc.
dgrace
« Reply #83 on: November 27, 2017, 06:48:49 pm »
Any suggestions on 120 mm usb (I don't know if they have to be USB??) fans for the arcade and where to buy from? I think I'm going to do 2 up top and 2 towards the bottom (on the backside).  Thanks
Drnick
  • Last login:Yesterday at 05:52:24 pm
  • Plodding Through Life
« Reply #84 on: December 01, 2017, 04:52:18 pm »
You don't have to get usb fans, just splice a pc power connector onto a dc power brick. (See below link) I found some LED speed controllable PC Fans which I put in mine.
