Lightguns --- Bug Reports --- Site News
Author Topic: Automatic Scanline Generator  (Read 2346 times)
jabsder
  • Last login:June 11, 2018, 01:25:03 pm
    • Arcade Cabinet and Retro Mods
« on: July 12, 2016, 03:29:56 am »
Hello, the most Scanline Generators have the options regulated over hardware.
- On/Off
- even/odd
- wide/thin scanlines
My Setup, in the future, is Mame with Mala, LedBlinky and one I-Pac Ultimate IO.
With LedBlinky i can control the Led Outputs. For example i turn a Led on if one Emulator is enabled.
I want to switch the scanline options with this Led Outputs over a ic circuit.
I dont tried this out. Is this way possible?
Sry for my bad english
  • Moderator
  • Last login:March 13, 2019, 01:02:20 pm
Re: Automatic Scanline Generator
« Reply #1 on: July 12, 2016, 09:23:36 am »
Hello!
Im not sure, but perhaps the ledblinky could do it?
Do you have a web link to the scanline generator you are thinking about using?
jabsder
« Reply #2 on: July 12, 2016, 12:21:08 pm »
  • Moderator
« Reply #3 on: July 13, 2016, 01:54:18 pm »
Hmmm, would it be possible to do what you want with relays?
It may be possible to control relays with the led blinky, I will have to research it more.
Relays could replace the switches.
