Author Topic: demul + g27 help  (Read 3938 times)
7theye
  • Last login:July 18, 2016, 11:28:40 am
demul + g27 help
« on: June 18, 2016, 01:02:36 pm »
Hi,
having immense trouble getting this configured. Have read everything - combine the pedals, push the clutch halfway - have tried for a soild hour and have been able to configure this to turn left or right even. Anyone have tips or know how to do this?
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
Re: demul + g27 help
« Reply #1 on: June 18, 2016, 08:29:50 pm »
Is the shifter in neutral?
7theye
« Reply #2 on: June 19, 2016, 11:40:37 am »
i ahvent attached the shifter
  • Moderator
« Reply #3 on: June 20, 2016, 09:09:44 am »
Not sure what else to tell you to try.
If nothing is working it could be your controller plugin settings.
Do you have other controllers connected?
Do you have the wheel rotation reduced to 270 degrees?
I've never heard of it happening, but 900 degrees may be too broad of a range for it to pick up the movement when mapping.
« Last Edit: June 20, 2016, 02:08:56 pm by BadMouth »
