Author Topic: Pink 1" t-molding?  (Read 1870 times)
quakebo
  • Last login:January 30, 2023, 02:13:01 pm
Pink 1" t-molding?
« on: June 08, 2016, 05:02:13 pm »
Does any one know where I can get some pink 1" t-molding?  Preferably in the uk but if not anywhere that will ship to uk will do.
Re: Pink 1" t-molding?
« Reply #1 on: June 08, 2016, 05:17:04 pm »
1" is an unusual size.  Do you mean 3/4"?
https://www.t-molding.com/3-4in-pink-t-molding.html
quakebo
« Reply #2 on: June 08, 2016, 06:05:52 pm »
My control panel is 18mm thick and when I get the artwork on it and the 3mm polycarbonate  on top of that it will be quite thick so wanted 1" then I can trim it down to size. I have not got polycarbonate yet so could get different thickness.
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #3 on: June 09, 2016, 05:05:01 am »
Any reason why you can't just have laminated vinyl printed removing the need for a plexi cover?
Pretty sure you can't get 1" t-molding but if it does exist it will probably be very expensive in pink. Probably cheaper to recut your control panel.
15mm MDF + Vinyl + 3mm Plexi and use 3/4" (19mm) t-molding
18mm MDF + Laminated vinyl and use 3/4" (19mm) t-molding
  • Last login:November 29, 2025, 04:34:53 pm
« Reply #4 on: June 09, 2016, 09:22:07 am »
You can definitely get 1" t-molding, as well as many other sizes. Check T-Molding.com, here, for a number of different sizes available. Unfortunately, at this time, it looks like they only have the pink t-molding in 3/4".
« Reply #5 on: June 09, 2016, 11:00:56 am »
You might be able to chamfer the bottom of your CP edge and still get by with 3/4 T-molding.
« Reply #6 on: June 09, 2016, 01:03:44 pm »
+1, only I'm not civilized enough to chamfer so I just run the edge of the CP top through the table saw to remove material from the bottom edge.
The the wider part is recessed 3/4" from the edge.  You'd have to get under it and look upwards to see it.
quakebo
« Reply #7 on: June 09, 2016, 01:45:02 pm »
I was going to go with a plexi cover because I thought it wood be better than having the artwork laminated and last longer.  Is this not the case will laminated artwork be just as good as a plexi cover?
« Reply #8 on: June 09, 2016, 02:21:10 pm »
Yeah that would work well also.   :cheers:
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #9 on: June 09, 2016, 02:41:03 pm »
I personally don't like Plexi over CP's. Plus you can always just have it reprinted if it doesn't wear well.
« Reply #10 on: June 09, 2016, 03:03:16 pm »
I have CP's with both and much prefer the ones without plexi.   One of them I need to take apart this summer and clean the dust out that got between the CPO and plexi.
quakebo
« Reply #11 on: June 10, 2016, 01:29:22 pm »
thanks for the help.   I will probably go with laminated art work for the control panel and 3/4" t molding.
