Author Topic: JAMMA pintout image has an error in it....  (Read 23201 times)
Arcadenut
  • Last login:October 10, 2023, 05:04:47 pm
    • Arcade Restoration Workshop
« on: March 11, 2016, 01:14:11 am »
http://wiki.arcadecontrols.com/wiki/JAMMA
The JAMMA pintout has Pins 20 and 21 reversed.
Pin 20 should be LEFT
Pin 21 should be RIGHT
Same for X and Y
Pin X should be LEFT
Pin Y should be RIGHT
[The link above is to the old wiki.  The new wiki page is at http://newwiki.arcadecontrols.com/index.php?title=JAMMA. -- Scott]
« Last Edit: March 11, 2016, 06:14:39 am by PL1 »
  • Last login:Today at 12:38:10 pm
Re: JAMMA pintout image has an error in it....
« Reply #1 on: March 11, 2016, 01:19:32 am »
He's right!
  • Last login:Today at 11:01:03 am
« Reply #2 on: March 11, 2016, 02:09:40 am »
Same for X and Y
Thanks for catching that.   :cheers:
Corrected version INW.
I know that the vertical spacing between pins is 0.156", but how much horizontal space do I have for the Pin#/description text?
I'd like to keep the text from hanging over the edge of the connector.
« Last Edit: March 11, 2016, 06:10:08 am by PL1 »
« Reply #3 on: March 11, 2016, 05:43:13 am »
How's this?
The .pdf should print to the correct vertical size.
The .zip file contains the .ods (Open Office Data Spreadsheet) file in case you want to change fonts, column widths, etc.
P.S. You linked to the old wiki.  New wiki page is http://newwiki.arcadecontrols.com/index.php?title=JAMMA.
« Last Edit: March 12, 2016, 05:12:10 am by PL1 »
Arcadenut
« Reply #4 on: March 11, 2016, 12:31:37 pm »
Looks good
ed12
« Reply #5 on: March 11, 2016, 12:49:40 pm »
your pin 5 and e ?
both should be -5v
not 12v on on the (pin5)
ed
« Reply #6 on: March 11, 2016, 01:33:59 pm »
your pin 5 and e ?
both should be -5v
ed
correct
« Reply #7 on: March 12, 2016, 05:16:38 am »
your pin 5 and e ?
both should be -5v
ed
correct
Not sure how that happened.   :dizzy:
Nice catch, guys.   :cheers:
Fixed and re-upped.   ;D
