Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: All Killer, No Filler MAME Gamelists Directory  (Read 255346 times)
franklesniak
  • Last login:May 26, 2020, 06:49:39 pm
Re: All Killer, No Filler MAME Gamelists Directory
« Reply #80 on: May 26, 2020, 06:49:39 pm »
OP, just wanted to say thanks so much for these lists.
I needed the All Killer, No Filler games in a consolidated, single list, and I wanted it in tabular (spreadsheet/Excel/CSV format) for my project, so I wrote a script to do just that. I'm sharing it here in case anyone else finds it useful:
https://github.com/franklesniak/ROMSorter/blob/master/Create-ConsolidatedAllKillerNoFillerGameList.ps1
Please contact me on Github with any follow-ups. I am new to the forums here and unsure how often I'll be signing in.
BTW, I have other similar scripts in the above Github repository that I am working on.
RyoriNoTetsujin
  • Last login:Today at 08:56:25 am
« Reply #81 on: July 03, 2020, 11:32:12 am »
Hey folks, long time no see.
Since I have nothing else to do... I'm updating my cabs for the first time in 5+ years. I haven't been here in a while either, so it was nice to see the All Killer No Filler lists. Maybe I'll do a version of these for special controls...?
Anyway, for those folks who are starting new and fresh, I've run BadMouth's original _NoFiller.txt batch file against Mame .222 and the only game files to throw errors are crimfght2.zip (replace with crimfghtu.zip) and vendetta2.zip (replace with vendetta2pw.zip or whichever version floats your boat.)
All other errors are BIOS/devices related, about 8 instances. Most have just been renamed, and can be tracked easily enough with mameinfo's NEWS.txt.  That said, if you're working with these newer versions of MAME, there's a BIOS/device subset out there that will distinctly simplify the process at a minimal 240MB space premium. Just copy that over after you've done NoFiller, and you'll be good to go, especially if you're thinking of adding any other games later in the process (no need to think about dependencies when they're all already there.)
Hawkguy
  • Last login:September 12, 2020, 11:44:52 pm
« Reply #82 on: July 20, 2020, 06:21:38 pm »
I have the 0.222 romset and I believe it's ... merged or split? About 50ishGB. Can I use this list? I thought deleting roms created problems with other roms? I'm not really sure how it works. I'm only interested in sports, fighters, and beat 'em ups, so I'd love to use this list.
« Last Edit: July 20, 2020, 06:31:10 pm by Hawkguy »
yamatetsu
  • Last login:Yesterday at 02:57:12 pm
  • Just because.
« Reply #83 on: July 21, 2020, 01:43:11 am »
This list doesn't delete any roms. You place the .bat file(s) into your roms folder, click on it (them), the .bat file(s) create a new folder(s) in your rom folder and copy the required roms there.
When done, you can make a backup folder, move your 50 gigs of roms into it, then move or copy the roms from the all killer folders into your rom folder. Test the games, if all run correctly, you can delete the backup folder.
Hogwild
  • Last login:August 10, 2020, 11:21:17 am
« Reply #84 on: August 10, 2020, 11:20:58 am »
Awesome list, and thanks for compiling these.  I do have a question though...I'm a complete Noob and starting from scratch.  I understand these were for an older version of Mame, but figured I would download the latest version since I'm starting new.  So will this work with 0223?  I've tried to follow instructions, but the command lines say they can't find any of the files (see attachment)
  • Last login:Today at 07:35:47 am
« Reply #85 on: August 11, 2020, 07:22:57 pm »
Any roms which MAMEdev has changed the name of will not work, but there are probably only a few (if any) that have changed.
You should still end up with almost all the files being copied over.
Is the batch file located in the same folder as the full set of MAME roms?
(this does require that you already have a complete set of MAME roms to copy from)
It could also be that your romset is .7z files instead of .zip files.
In that case, see the related note in red at the bottom of the first post.
zeroize
Please delete
« Reply #86 on: August 13, 2020, 11:45:16 am »
Thank you
« Last Edit: September 19, 2020, 06:41:48 am by zeroize »
keilmillerjr
  • Last login:June 18, 2022, 03:29:12 am
  • Web Developer.
« Reply #87 on: August 19, 2020, 02:44:30 pm »
I created a commit and PR was accepted for nofiller tag list added to attract-mode. I created a plug-in that will copy files based on romlist or tag list. It works with windows, Mac and Linux. Will assemble a commit and PR soon for that soon.
mahuti
  • Last login:March 02, 2022, 09:51:19 pm
« Reply #88 on: August 19, 2020, 06:15:50 pm »
Genius. Thank you.
Cappy
  • Last login:April 15, 2021, 03:39:17 pm
« Reply #89 on: August 26, 2020, 07:35:59 am »
I made various playlist with this work for Launchbox. I share them on the LB forum.
Envoyé de mon Nexus 4 en utilisant Tapatalk
Nice one! Do you have a link please?
fablog
  • Last login:Today at 01:11:52 am
csnow
  • Last login:June 16, 2022, 09:47:16 pm
« Reply #91 on: September 25, 2020, 08:41:19 am »
I just wanted to say thank you again for this.
Reggie10
  • Last login:September 21, 2021, 05:41:16 pm
« Reply #92 on: January 13, 2021, 12:44:46 pm »
Thanks for your work on this. It's saved me a ton of aggravation and it's crazy that five years later this continues to be an important resource people use to wrangle the chaos that is a MAME romset.
I wanted to ask how you decided which version of a game to include. Was it influenced by parents vs. clones, so that people with a merged set don't break anything? Are there artistic or gameplay differences that might make one version superior to another? Did you try to prioritize the U.S.? I ask because it seems the batch file has some U.S. versions of games but then international versions of others (ex. Japanese Double Dragon, European Dungeons and Dragons). Just curious. I'm thinking of converting my split set to unmerged and tweaking the batch file to prioritize U.S. versions, but will refrain from doing so if there were specific reasons you chose the versions you did.
Thanks again for all you've done for the community.
« Last Edit: January 13, 2021, 12:47:30 pm by Reggie10 »
« Reply #93 on: January 13, 2021, 09:47:13 pm »
IIRC, I went with the parent provided it was in english.
Usually the international was and didn't include the extra "winners don't use drugs" loading screen.
In general, the gameplay in Japanese versions are considered to be more fair while US versions were tweaked to force you to insert more quarters to progress, but I prioritized language.
I don't recall why the Japanese version Double Dragon was chosen.  There might be discussion of it in the beat em up thread, or it may have just been the parent.
.....or I don't have any real reason.
mahuti
« Reply #94 on: January 14, 2021, 10:52:01 am »
...didn't include the extra "winners don't use drugs" loading screen
If there is an option in the dipswitches for this i always turn it on.  :laugh:
My cab's loading screens all include this. Its.just not the same without it.
cosmo0
  • Last login:March 17, 2021, 06:13:01 pm
« Reply #95 on: March 15, 2021, 05:16:33 pm »
Hello
I've made a too to manage romsets, and I provide pre-built lists : https://cosmo0.github.io/arcade-manager/ (it says Retropie & Recalbox but rom management work for everything)
Would you agree to let me use your lists in my app? I was planning on doing the same kind of list, but if I can use it it'll let me gain much time.
If you don't want I understand, I'll just have to list them myself  :'(
Thanks! :)
Firebat138
  • Last login:November 10, 2021, 12:19:00 pm
  • Head Brewer and Arcade Enthusiast
« Reply #96 on: March 16, 2021, 09:20:56 am »
Awesome, thanx man
Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0
Click below to see my PinCab - PinWARS
http://forum.arcadecontrols.com/index.php/topic,164660.0.html
« Reply #97 on: March 16, 2021, 08:36:50 pm »
Hello
Thanks! :)
Sure.
cosmo0
« Reply #98 on: March 17, 2021, 06:13:02 pm »
Sure.
Thank you so much! It'll save me a ton of time :)
G22
  • Last login:June 01, 2021, 11:29:35 pm
  • Don't lose your nights, they're half your life.
« Reply #99 on: March 29, 2021, 03:28:28 pm »
Hi, I've been using your lists for quite some time now and I can definitely say they're awesome!
I'd like to expand the AKNF project with roms that only works in other emulators than Mame. I'm starting with these lists I made based on community ratings and that it works on 4/8 way joysticks with 6 buttons + coin/start. I don't want to include gun games, racing games or other non standard control games. I don't know if these games are any good or any bad. I'd like your help to update those lists to fit in the AKNF criteria.
Sega Naomi - Demul
ausfache          "Akatsuki Blitzkampf Ausf. Achse (Japan)"
azumanga          "Azumanga Daioh Puzzle Bobble (GDL-0018)"
beachspi          "Beach Spikers (GDS-0014)"
capsnk            "Capcom Vs. SNK Millennium Fight 2000 (Rev C)"
cleoftp           "Cleopatra Fortune Plus (GDL-0012)"
cvs2              "Capcom Vs. SNK 2 Mark Of The Millennium 2001 (USA) (GDL-0008)"
cvsgd             "Capcom Vs. SNK Millennium Fight 2000 Pro (Japan) (GDL-0004)"
doa2m             "Dead or Alive 2 Millennium"
ggx               "Guilty Gear X"
ggxx              "Guilty Gear XX (GDL-0011)"
ggxxac            "Guilty Gear XX Accent Core (Japan) (GDL-0041)"
ggxxrl            "Guilty Gear XX #Reload (Japan, Rev A) (GDL-0019A)"
ggxxsla           "Guilty Gear XX Slash (Japan, Rev A) (GDL-0033A)"
ikaruga           "Ikaruga (GDL-0010)"
mamonoro          "Mamoru-kun wa Norowarete Shimatta! (Japan)"
mvsc2             "Marvel Vs. Capcom 2 New Age of Heroes (Export, Korea, Rev A)"
pstone            "Power Stone"
pstone2           "Power Stone 2"
psyvar2           "Psyvariar 2 - The Will To Fabricate (Japan) (GDL-0024)"
sfz3ugd           "Street Fighter Zero 3 Upper (Japan) (GDL-0002)"
sgtetris          "Sega Tetris"
slashout          "Slashout (GDS-0004)"
spkrbtl           "Spikers Battle (GDS-0005)"
sprtjam           "Sports Jam (GDS-0003)"
tetgiant          "Tetris Giant / Tetris Dekaris (Ver.2.000)"
tetkiwam          "Tetris Kiwamemichi (Japan) (GDL-0020)"
undefeat          "Under Defeat (Japan) (GDL-0035)"
vathlete          "Virtua Athletics / Virtua Athlete (GDS-0019)"
vf4cart           "Virtua Fighter 4 (World)"
virnba            "Virtua NBA (USA)"
vonot             "Virtual On Oratorio Tangram M.S.B.S. ver5.66 2000 Edition"
vs2_2k            "Virtua Striker 2 Ver. 2000 (Rev C)"
vstrik3           "Virtua Striker 3 (GDS-0006)"
vtennis2          "Virtua Tennis 2 / Power Smash 2 (Rev A) (GDS-0015A)"
vtennisg          "Virtua Tennis / Power Smash (GDS-0011)"
wwfroyal          "WWF Royal Rumble"
zerogu2           "Zero Gunner 2"
Sammy Atomiswave - Demul
demofist          "Demolish Fist"
dolphin           "Dolphin Blue"
fotns             "Fist Of The North Star"
ggisuka           "Guilty Gear Isuka"
ggx15             "Guilty Gear X ver. 1.5"
kofnw             "The King of Fighters Neowave"
kofxi             "The King of Fighters XI"
kov7sprt          "Knights of Valour - The Seven Spirits"
mslug6            "Metal Slug 6"
ngbc              "NeoGeo Battle Coliseum"
rumblef           "The Rumble Fish"
samsptk           "Samurai Spirits Tenkaichi Kenkakuden"
Sega Model 2 - Model2
doa               "Dead or Alive (Model 2B, Revision C)"
dynamcop          "Dynamite Cop (Export, Model 2A)"
fvipers           "Fighting Vipers (Revision D)"
lastbrnx          "Last Bronx (Export, Revision A)"
schamp            "Sonic Championship (USA)"
vf2               "Virtua Fighter 2 (Version 2.1)"
zerogun           "Zero Gunner (Export, Model 2B)"
Sega Model 3 - Supermodel
fvipers2          "Fighting Vipers 2 (Japan, Revision A)"
spikeofe          "Spikeout Final Edition (Export)"
vf3               "Virtua Fighter 3 (Revision D)"
vs298             "Virtua Striker 2 '98 (Step 2.0)"
I've tested all those games 1 by 1 and they all work great so they could potentially be good candidates for AKNF.
Any help is greatly appreciated!
BigCaah
  • Last login:Yesterday at 09:24:42 pm
  • Learning new skills through old hobbies
« Reply #100 on: April 17, 2021, 08:26:41 am »
Awesome lists, thank you for putting these together!
« Reply #101 on: April 21, 2021, 09:03:45 pm »
Sega Naomi - Demul
ggx               "Guilty Gear X"
If you look at the threads for the individual lists, games from these emulators are included.  (the ones I thought worthy anyway)
G22
« Reply #102 on: June 01, 2021, 11:29:36 pm »
Thanks for replying I just saw that. Still I think it's sad that there's not many people left on this forum to keep such a thread active. Since you made these lists there are so many improvements in emulation and the Mame set. I think it would be great to have the input of arcade connoisseur to relive those lists.
Have a great day!  :) :afro:
vaderag
  • Last login:April 15, 2022, 12:56:37 pm
  • Building my own cab :)
« Reply #103 on: August 26, 2021, 06:55:27 am »
Will these batch files will work with latest Mame sets (234?)
If not, are there plans to update at all?
« Reply #104 on: August 26, 2021, 12:00:39 pm »
....probably mostly.  If MAMEdev have changed the name of a rom or split part of the rom out (like moving a sound board to a separate rom), then those will be missed.
I have no interest in updating it.
bjhille
  • Last login:March 20, 2022, 10:20:13 pm
« Reply #105 on: September 14, 2021, 06:24:29 pm »
I just ran the bat files against Mame 0.235 (non-merged) and found the same issues as previously reported, plus one more.  I believe all the other erros are bios files and/or sound files.  The ones you need to do something with are:
* crimfght2.zip (replace with crimfghtu.zip)
* vendetta2.zip (replace with vendetta2pw.zip or whichever version floats your boat)
* wc90.zip (replace with ?)
It looks like wc90.zip is "Tecmo World Cup '90".  Can someone show me where to look or could you help me identify the replacement in Mame .235?
Also, how do I found out what the different versions are for vendetta2 (vendetta2pd.zip, vendetta2peba.zip, vendetta2pp.zip, vendetta2pu.zip, vendetta2pun.zip, and vendetta2pw.zip)?
Thanks.
« Last Edit: September 14, 2021, 06:27:05 pm by bjhille »
Banane
  • Last login:June 08, 2022, 08:35:28 am
« Reply #106 on: June 08, 2022, 08:35:51 am »
I know, there are other solutions around, but to keep it really simple I just updated the original batch file from 2016.
It now works with a 0.244 romset as well.
Yenome
  • Last login:June 16, 2022, 08:49:52 pm
  • Punch a fish. Make a wish
« Reply #107 on: June 10, 2022, 06:26:13 pm »
i was about to do this my self. had updated it for 206. Wmsnarc.zip is a device file for the game narc its the sound board it may or may not be needed still
« Last Edit: June 10, 2022, 06:44:59 pm by Yenome »
