Author Topic: ArcadeDepot CP dimensions  (Read 1247 times)
martini
  • Last login:February 27, 2005, 12:44:51 pm
    • Martini Arcade
« on: December 26, 2003, 01:19:26 pm »
Can anyone with a cocktail cabinet from ArcadeDepot tell me what the exact dimensions of the control panel is?  If you know the dimensions of the 3rd CP that would also be useful.
I'm planning a project and want to layout the CPs in a scale drawing.
Thanks in advance
martini
    • Martini Arcade
Re:ArcadeDepot CP dimensions
« Reply #1 on: December 29, 2003, 02:02:04 am »
There has to be someone out there that knows.  Supossedly it is based on a Ms. Pacman cocktail table so it may have the same dimensions (at least for the ends).  The 3rd panel is on the side.  I've emailed the people at arcadedepot so hopefully I will hear back from them.
daeven
  • Last login:July 15, 2022, 12:17:33 pm
  • Llama this!
« Reply #2 on: December 29, 2003, 11:41:37 am »
I am in the middle of building an ArcadeDepot cocktail.  They are the 9" wide control panels (I do not have the third panel option).  I believe their webpage has a jpeg that you can use to see/design the usable area of the control panel.  If you want more measurement info, post what you are looking for - I can measure everything tonight.
It is based on the Ms. Pacman cocktail.  BTW, there was also a Ms. Pacman that had 11" wide control panels.
BTW, I highly recommend these kits.  I was going to build completely from scratch, but for the price, I think it is hard to beat.
martini
    • Martini Arcade
« Reply #3 on: December 29, 2003, 12:55:43 pm »
Thanks!  What is the depth of the CP?
I worked with the JPEG a little bit, but quickly found it wouldn't work.   I'm using t-stiks from ultimarc and they have a different hole pattern.
