Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: How to enable HLSL or GLSL in SDLmame on a mac  (Read 7887 times)
Locke141
  • Last login:Today at 08:15:22 pm
  • Never grow up.
« on: February 02, 2015, 06:14:49 am »
I know this is not linux but I thought this would be a better place to ask as its SDL mame on a unix like system.
I'm trying SDLmame on my macbook running OS X Yosemite with 0.157 64bit. I managed to create an .ini but nothing seem to work. My mame executable is called mame64 but the .ini is called mame.ini. I tried hanging the names of one then the other to match with no luck.
I just want something simple that will look good on my 90's games.
B2K24
  • Last login:December 09, 2019, 07:12:11 pm
Re: How to enable HLSL or GLSL in SDLmame on a mac
« Reply #1 on: February 02, 2015, 04:17:23 pm »
HLSL is Windows only so you can't use it in SDL builds. You can use a shader using the GLSL system.
http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=330562&page=0&view=expanded&sb=5&o=&vc=1
basically you change video to opengl in the mame.ini
filter                    1
prescale                  1
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   1
gl_glsl_filter            1
glsl_shader_mame0         C:\SDLMAME\CRT-geom\Lottes_CRT
Locke141
  • Never grow up.
« Reply #2 on: February 03, 2015, 05:13:56 am »
Thanks B2k24,
I signed up for mame world and got the file and followed your directions but I can't get it to work. I get the incomplete graphics warning then nothing.
I got the version named 332176-Lottes_CRT_VERT_SEP_10 I tried it that renaming it to Lottes_CRT still no go.
Any ideas?
« Last Edit: February 03, 2015, 06:50:42 am by Locke141 »
Locke141
  • Never grow up.
« Reply #3 on: February 03, 2015, 06:48:54 am »
Thanks B2K24,
6-player x-man ver uce will not start with the above settings but TMNT will  and other games but with now shaders?
I set my path as /Applications/qmc2 /mame0157-64bit/Lottes_CRT
Below is what my terminal came back with.
Last login: Tue Feb  3 14:43:51 on ttys000
Locke:~ brian$ /Applications/qmc2\ /mame0157-64bit/mame64\ Starter.command ; exit;
cannot open shader_file: /Applications/qmc2 /mame0157-64bit/Lottes_CRT.vsh
OpenGL: GLSL loading mame bitmap shader 0 failed (/Applications/qmc2 /mame0157-64bit/Lottes_CRT)
Average speed: 100.00% (15 seconds)
logout
[Process completed]
« Last Edit: February 03, 2015, 07:01:11 am by Locke141 »
Arbee
  • Last login:September 29, 2019, 10:05:12 am
« Reply #4 on: June 02, 2015, 04:23:03 pm »
Sorry to necrothread, but do you mean to have a space in the directory name "qmc2 "?  Because that looks like an obvious problem vector.
alfonzotan
  • Last login:May 07, 2019, 08:30:49 am
    • The Cab With No Name
« Reply #5 on: June 24, 2015, 10:44:13 am »
I put up a long post on Mac MAME-ing a while back, including HLSL shaders.  See if this helps:
http://forum.arcadecontrols.com/index.php/topic,138555.msg1431121.html#msg1431121
Locke141
  • Never grow up.
« Reply #6 on: June 24, 2015, 04:33:18 pm »
Thanks guys,
I was playing with qmc2 at the time and that was the correct path at the time, I think. Now I'm using Attract mode on the mac.
alfonzotan I'll definitely take a look. :cheers:
Update: Thanks Alfonzotan, I like EMU launcher. It feels like a mac application.
« Last Edit: June 25, 2015, 01:50:17 am by Locke141 »
