Author Topic: Gran Turismo 2 and a lot more games on PSX emu with real Analog controls  (Read 28796 times)
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
I finally found a way to play GT2 with my steering wheel (properly). I say properly because the epsxe emulator let you set analog controls to a dual shock controller but the deadzone is so terrible, it makes games unplayable with a steering wheel. In comes the NeGcon Controller and NeGcon plugin for epsxe. The NeGcon controller is a PS1/PS2 controller created by Namco as handle held analog control for Ridge Racer. You can read more about here http://en.wikipedia.org/wiki/NeGcon but, the actual NeGcon controller is not needed for this to work, just the NeGcon plugin for epsxe.
Things you will need.
epsxe 1.90
http://www.epsxe.com/
NeGcon Plugin (padgnneco0_06.zip)
https://mega.co.nz/#!dZN11KpC!muXo35Y0C6k1rSGZqyRHRezf_kLWyGqbRZbm6OOqsjo
A Negcon compatible game (listed at the bottom)
1. Place the contents of the NeGcon zip into your plugins folder. Then open and setup epsxe (bios, paths, etc).
2. Go to config and set up pad1. use the drop down to configure the NeGcon. The NeGcon has 4 analog Controls, the L button, the center Twist, I button and II button.
The Center Twist (green) is your Steering
The I Button is Accel
The II Button is Brake
The L button usually shift
The L Button is a pain is because its an analog button and the plugin does not let me map it a button, only an axis. Since my Steering wheel only has 3 axis, I cant map this to anything and by default, it mapped to be fully pressed. I didnt notice this in Ridge Racer but I did notice this when I played GT2 since L button is rear view camera and when I played, the camera was always pointing to the rear.
There are two ways around this issue in GT2, you can go into the actual games setting in GT2 and change the L button to something else like change camera view (you will lose the ability to change camera view) but atleast the default camera will be pointing forward or what I ended up doing was turning on my xbox controller and mapping the L button the my left stick axis (I lose the ability to use rear view camera but, that something I probably wont use anyways)
3. load your iso and hit F5 to turn on your NeGcon Controller You must hit F5 to enable it!!! You will see a NeGcon appear if you did it correctly
4. Play NeGcon Compatible Games with proper Analog controls.
Here is a list of Compatible NeGcon Games (I have only tested Ridge Racer and GT2 so far)
UPDATE: I found a more complete list with even more games!
http://www.rolling-start.com/forum/viewtopic.php?f=14&t=26
Title   Comments
Ace Combat
Ace Combat 2
Ace Combat 3
Advan Racing
Aquanauts Holiday   No twist support
Atari Anniversary Edition Redux
Auto Destruct
Burning Road
Choro Q 2
Choro Q 3
Colin McRae Rally
Colin McRae Rally 2.0
Cool Boarders 2
Crash Team Racing
Cybersled
Dakar 97
Destruction Derby
Destruction Derby 2
Destruction Derby Raw
Explosive Racing
Extreme 500   aka. Suzuki Alstare Challenge
Felony 11-79/Runabout
Formula 1
Formula One 2000
Formula One 2001
Galaxian 3
Gran Turismo
Gran Turismo 2
Grand Tour Racing 98
GT All Japan Touring Car Championship
GT Max Rev
Hyper Rally
Initial D
Italian Job
Js Racin
Jupiter Strike   Lack of twist support causes issues, according to reports
Kattobi Tune
Max Power Racing   aka. C3 Racing
MaxRacer
Meisha Retsuden - Greatest 70s
Mille Miglia
Motorhead
Motor Toon Grand Prix
Motor Toon Grand Prix 2   aka. Motor Toon Grand Prix in US
Mr. Driller   Works a little, but necessary button functions are missing.
Namco Museum 1   Twist support in Pole Position only, all games fully playable.
Namco Museum 3   Twist support in Pole Position II only, all games fully playable.
Naniwa Wangan Battle
Nascar 2000
Need For Speed
Need For Speed 2
Need For Speed 3 - Hot Pursuit
No Fear Downhill Mountain Biking
Option Tuning Car Battle 2
Race Drivin Go Go
Racingroovy
Rage Racer
Rally Cross
Rally Cross 2   Fully playable, but track editor might not be 100% usable with Negcon.
RC de Go!
Red Asphalt   aka. Rock n Roll Racing 2
Ridge Racer
Ridge Racer Revolution
Ridge Racer Turbo/Hi-Spec   Not compatible with Interact V3.
Ridge Racer Type 4   Not compatible with Interact V3.
Rollcage
Rollcage Stage II
Runabout 2
Rush Hour   aka. BattleRound USA aka. Speedster
San Francisco Rush   Save menu not fully compatible, otherwise fine
Shutokou Battle R
Side-by-Side Special 2000   Did not seem to work correctly when run on a PS2. Works extremely well on a PS1.
Speed King
Starblade Alpha   No twist support
Street Scooters
Tekken 2   Believed to be supported, as it is listed on the back of the box. Twist support unknown.
Tekken 3   Believed to be supported. Twist support unknown.
Tempest X3
Test Drive 4
TNN Motor Sports Hardcore 4x4
TOCA Championship Racing   aka. TOCA Touring Car Championship
TOCA 2 - Touring Car Challenge   aka. TOCA 2 - Touring Cars
TOCA World Touring Cars   aka. Jarrett and Labonte Stock Car Racing aka. WTC - World Touring Championship
Tokyo Highway Battle   Recognized, but twist and L button not supported. Not enough buttons for all functions.
Tommi Mäkinen Rally
Touge Max
Touge Max G
Toyota Netz Racing
Twisted Metal   Recognized in menus, but game cannot be properly configured for the Negcon.
V-Rally
V-Rally 2   Track editor might not be fully operable with Negcon. Not compatible with Interact V3.
Wangan Trial
Wipeout
Wipeout 2097/XL
Wipeout 3
World Stadium 2
World Stadium EX
Wreckin Crew
Xevious 3D/G+
« Last Edit: November 17, 2014, 01:21:52 am by SegaOutrun »
Fursphere
  • Last login:Yesterday at 07:07:08 pm
Re: Gran Turismo 2 and Ridge Racer on PSX emu with real Analog controls
« Reply #1 on: November 16, 2014, 08:41:57 pm »
Nice work!  I'm going to have to finally get this emulator working on my cabinet...
Loafmeister
  • Last login:December 08, 2020, 03:21:17 am
« Reply #2 on: November 16, 2014, 08:59:30 pm »
Same here, just got supermodel working with the racing cab last night (&(${^*%+ pedals...) and now I feel like I am hearing my racing cab talk to me.  I think I am going to name her "Audrey". ;)
SegaOutrun
« Reply #3 on: November 17, 2014, 01:18:26 am »
i just tried Side by Side: Special, it works perfectly with the NeGcon plugin. I have a new fav game at the moment. Which is great news because it never played well in mame. I cant wait to try other games
  • Moderator
  • Last login:March 17, 2024, 08:21:52 pm
I really wish they'd get rid of the need to press F5 for analog.
EDIT: Added this list to the "what to play" stickied thread.
DOUBLE EDIT: I played GT2 once on my arcade cab a few yars ago.  It took so long to get to actual gameplay that I never launched it again.  :lol
« Last Edit: November 17, 2014, 11:21:30 am by BadMouth »
Sp3c7r3
  • Last login:March 09, 2016, 02:09:52 am
I would love this if I could actually find an image of Ridge Racer that wasn't in some ---That which is odiferous and causeth plants to grow--- format  :angry:
MrThunderwing
  • Last login:Yesterday at 05:57:23 pm
  • As I pass, do I give you the ass or the crotch?
Cool thread. It's a shame to see that Ray Tracers isn't on that list though, it's a real fun Chase HQ style arcade racer. I used to own a Jogcon back in the PS1 days purely for Ridge Racer Type 4. It was a fun little peripheral but I don't think it really added to the game much and if anything I used to do worse when I was using it compared to a regular dual shock pad. I wonder if there are any Jogcon plugins for ePSXe that can enable FFB in wheels for stuff like Ridge Racer Type 4?
SegaOutrun
I can confirm that that Ray Tracers work. I added a few games to my cabinet today. i can confirm that Initial D, Wagan Battle, Touge G max and Crash Bandicoot Team Racing work with the NeGcon Plugin. Sadly Midnight Run (Road Fighter 2) does not work.
Btw for Ray Tracers, only the Euro and Japanese version have the Anime Storyline Dialogue. The US version doesnt have it.
Loafmeister
So the $0.50 question, are the games super fun to play?  Do they control fairly flawlessly?  (ie:  similar to how they did on the PS1 or is it one of those "at least it works and control is acceptable? ... which isn't a bad thing).
MrThunderwing
Sweet!
SegaOutrun
Re: Gran Turismo 2 and a lot more games on PSX emu with real Analog controls
« Reply #10 on: November 18, 2014, 10:44:55 pm »
So far Side by Side Special 2000, Initial D, Ridge Racer(s) and Touge G Max are games I see myself playing often. The Steering in those games actually feel like if I was playing an arcade version of the game.
I actually had Initial D for the PS1 but, I only had a regular controller so I thought it suxed. Ive only played it with my wheel for about 30min but im already loving the way it handles and slides.
  • Last login:March 17, 2024, 01:15:07 pm
« Reply #11 on: November 19, 2014, 09:48:33 am »
what FE are you using? if its MaLa teach me how to add PSX to the menu :)
  • Moderator
« Reply #12 on: November 19, 2014, 09:59:49 am »
He uses hyperspin.
IIRC, ePSXe is covered in UncleT's ancient guide.
« Reply #13 on: November 19, 2014, 10:01:42 am »
UncleT's guide needs updated in the worst way and Im not the guy to do it.
  • Moderator
« Reply #14 on: November 19, 2014, 10:25:21 am »
I bailed on adding it to my old cab because I didn't want to deal with the having to press F5 to activate analog controls thing.
I'm sure we could find an autohotkey solution.
Same here on Uncle T's guide.  I owe a lot to the guide for helping me through my first setup.
But after messing with this stuff long enough to understand everything, I really dislike the file structure he chose.
The thought of people bugging me every time something doesn't work because they're missing runtimes, didn't follow the instructions, or are running some stripped down version of windows ensures that I will never bother.
Sp3c7r3
« Reply #15 on: November 19, 2014, 10:52:27 am »
On www.rolling-start.com they made a list of NegCon compatible games.
SegaOutrun
« Reply #16 on: November 19, 2014, 04:45:14 pm »
I dont know if this is hyperspin doing this or epsxe but I dont have to push F5 every time. It remembered my settings. For example, Last night I was playing initial D, exited and played Side by Side in hyperspin and I didnt have to push F5. It remembered my control configuration.
Sp3c7r3
« Reply #17 on: November 20, 2014, 01:36:40 am »
I just realised that this might be the best way to play Pole Position without a 360 degree wheel! According to rolling-start.com, Namco Museum 1 has NegCon controller support. Now I HAVE to get this working  :notworthy:
Loafmeister
« Reply #18 on: November 20, 2014, 06:52:34 am »
That is true, i remember playing PP with a buddy's negcon back in the day!  Forgot about that.
... I wonder if buggy boy and other 360 wheel games have ever been released on other systems with some form of analog control that would make them playable with a g25/27 wheel?
SegaOutrun
« Reply #19 on: November 20, 2014, 10:23:33 am »
MrThunderwing
« Reply #20 on: November 20, 2014, 07:52:48 pm »
Nice compilation video mate. I must admit I've never been a fan of sim racers, but I gotta say those car models in Gran Turismo 2 look exceptionally nice for a PS1 era game.
Loafmeister
« Reply #21 on: November 21, 2014, 10:48:24 am »
Very nice comp video indeed.  Most of these never heard of before but once I saw that I had a ball playing was Motor Toon Grand Prix 2, great game if you come across it IMHO.  I think I liked Ridge Racer Revolution more than the original.  This just motivates me to set this PSX emulator up on the racing cab... once I finish my current mame setup (which feels like its going to take forever.  360 wheel games on a G25 setup appear to be EVIL incarnate!)
Sp3c7r3
« Reply #22 on: November 28, 2014, 02:19:08 pm »
I'm having a few problems. When I want to setup my controls for NegCon the analog axis work fine but any other regular pushbutton is impossible to set to anything on the wheel as ePSXe somehow thinks my pedals are pressed? Does the emulator require combined pedals?
Also, I'm experiencing a huge deadzone. Any way to get rid of that? I have a Logitech G27
SegaOutrun
« Reply #23 on: November 28, 2014, 08:38:03 pm »
for the buttons. hold the button you want to map until it shows up (you may have to tap it a few times), then while holding that button click on the next button box. it save the button selected in the last box when you move on the next one and repeat the process(map your pedals last). As for the dead zone, are sure that you have the negcon plugin turned on "hit f5 in-game and you should see a negcon controller appear for a few seconds". What game are you playing? I have a driving force gt which is also 900* degrees like the g27 and i dont have any deadzone issues (although some games do play alot better than others)
Sp3c7r3
« Reply #24 on: November 29, 2014, 06:01:26 am »
I have pressed F5 for NegCon controls  ;)
I've only tried Pole Position in Namco Museum Vol 1 so far. I have to check my profiler settings. Maybe the turn radius on the wheel is crazy, so I will set it to 200 degrees and try that, because right now I can turn the wheel to 11  and 1 o'clock without the emulator registering in game.
  • Moderator
« Reply #25 on: November 29, 2014, 09:17:57 am »
F5 activates analog control.  The game might be seeing a dual shock controller if you don't see the NegCon.
For console and very old PC games, I usually set the rotation to 180 or 200 degrees.
For games that were designed only to be played with an analog thumbstick which can change directions way faster than you could move a steering wheel, I've gone as low as 150.  You just can't change direction as quickly as the game requires otherwise.
Sp3c7r3
« Reply #26 on: December 13, 2014, 02:16:19 pm »
Finally got around to mess with ePSXe again. Setting the wheel to 200 degrees worked wonder with Pole Position. Now setting up the buttons for the NegCon plugin is a pain in the bum. Is there a file I can edit instead as this is just impossible?
For some reason L1 is set to my g27 clutch pedal and nothing I do can change that.
ant2
  • Last login:March 07, 2024, 08:30:50 am
had a go at this today.
G27:
gran turismo 1 - the throttle keeps engaging and disengaging, so the car never moves
grant turismo 2  - massive dead zone in the middle, unplayable even with modifying the wheel between 40-300 degrees
colin mcrae - slight dead zone in the middle, no matter how much you restrict the wheel, but it is much better than dual shock.
theravenousbeast
  • Last login:May 12, 2016, 06:58:58 pm
Huge deadzone in GT2 for me as well. No matter the degrees set. Driving Force GT is the wheel I use. Any ideas?
Insayne
  • Last login:November 17, 2022, 04:19:53 pm
Hey,
I found with EPSXE i get a huge Deadzone regardless of the Plugin used.
With PCSX-R, things work out fine. Maybe try that?
isamu
  • Last login:March 18, 2024, 02:38:32 am
I am hoping someone will hack in JoGcon support or create a JoGcon plug-in for PCSX-R. I really want to play Ridge Racer Type 4 and GT 2 with force feedbaque.
MrThunderwing
^ This  :cheers:
Moksi
  • Last login:March 18, 2024, 09:10:04 am
« Reply #32 on: February 11, 2018, 07:15:25 pm »
i tried messing with Destruction Derby 2 but NEgcon wont allow you to start the game , only choose car track unfortunately
