Author Topic: wg 27d9200  (Read 1115 times)
harbngr
  • Newbie
  • Last login:February 13, 2015, 06:58:37 pm
wg 27d9200
« on: June 21, 2014, 10:40:24 am »
Just looking for some advice and guidance.
I got a wg 27d9200, was told the flyback was bad. So I replaced that and did a cap kit on it. Now when I power it with/without a signal I get a blank screen. if I turn up the brightness I get a white screen.
I do not get an OSD, or even a no signal display when I do not have anything plugged in.
Thanks in advance
Jerry
grantspain
Re: wg 27d9200
« Reply #1 on: June 21, 2014, 10:54:25 am »
it could be ic201 on the neck card plus you will need to check +5v and +12v
check the video interface pcb and connections
it also possible ic101 is faulty
