Author Topic: WG monitor super fuzzy and green :(  (Read 1413 times)
samv
  • Last login:June 20, 2014, 04:16:19 pm
« on: June 18, 2014, 12:16:50 pm »
WELLS-GARDNER ELECTRONICS CORP
MODEL NO: 25K7191
CHASSIS SERIAL NO: WG629967
CHASSIS SERIAL NO (2): 12591
BOARD STAMP: P538
120V 60Hz 100W MAX
MANUFACTURE DATE: JANUARY 1991
Hello everybody. My wife got me a Marvel Super Heroes Vs. Street Fighter arcade cabinet about a year ago. It worked great until the other day. While I was playing, the picture went from perfect to what you can see in the attached pictures. I've never troubleshot a CRT and I don't even know where to begin. Is this a common problem? Will somebody please help me troubleshoot this?
Ken Layton
  • Guru
  • Technician
Re: WG monitor super fuzzy and green :(
« Reply #1 on: June 18, 2014, 12:57:17 pm »
Flyback is probably going out.
samv
« Reply #2 on: June 18, 2014, 03:47:07 pm »
Thank you ken, I just ordered a new one and I will try to change it out when I get it.
NOTE TO ANYONE ELSE READING THIS:
Removing the flyback can be dangerous, do some research before you try it.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #3 on: June 19, 2014, 08:51:36 am »
I'd also check the solder joints on the 3 transistors on the neckboard.
I know on my WG monitor, 2 of 3 have broken traces and need stitch soldering to repair.
My screen is also "All green", but when I wiggle the transistors, the other colors come in just fine.
samv
« Reply #4 on: June 20, 2014, 12:37:15 pm »
Noted, thanks for the response, I'll take it apart this weekend and check the connection on those transistors.
Sarver Systems
« Reply #5 on: June 20, 2014, 04:08:02 pm »
They have little heatsinks on them, which add some weight to them. If the heatsinks were soldered to the board as well, it would be a much better design!
