Author Topic: Custom metal control panel (i.e. Midway/Namco style)  (Read 2315 times)
slbailey
  • Last login:October 04, 2016, 12:47:43 pm
« on: February 19, 2014, 09:19:47 pm »
I'm using sketchup to design my new project and it's going to be a custom cabaret cabinet in the pac man/ms pac man/galaga style.  To that end, I'm trying to find out if there's a place to get a custom cut metal control panel that's in the namco/midway style.  I want a simple player one, player two, 4 way joystick and single fire button configuration... The challenge is the width of the control panel is going to be unique.  Ideally I'd like to get a black powder coated metal panel that I can just apply an overlay graphic to.
Does such a service exist?
Steve
mgb
  • North East, US
Re: Custom metal control panel (i.e. Midway/Namco style)
« Reply #1 on: February 19, 2014, 11:42:43 pm »
One possible solution may be going to a local metal shop with the measurements and seeing if they can fabricate it.
The Midway style metal control panel is a fairly simple design.
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #2 on: February 20, 2014, 12:03:54 am »
It's been a long time since I looked...but I remember their being a vendor selling pac-galaga CPs either drilled or undrilled...
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
« Reply #3 on: February 20, 2014, 06:29:20 am »
What is the advantage to using metal as opposed to just machining something out of wood for this?
In just about any town there is a metal fabricator, usually not cheap but not outrageous either. Just look up your local yellow pages once you have your plans down.
slbailey
« Reply #4 on: February 20, 2014, 09:02:07 pm »
I could go wood but I'm trying to go authentic... Weight is the main reason... I'm trying to make it as light as possible.  If metal doesn't pan out then I will go wood.
Well Fed Games
  • Delicious!
« Reply #5 on: February 20, 2014, 09:43:49 pm »
https://www.mikesarcade.com/cgi-bin/store.pl has upright and cocktail blanks, but nothing cabaret sized.
« Reply #6 on: February 20, 2014, 09:57:28 pm »
For me it'd be that the original 4ways were made for metal and if you put one of those on a wood CP, no enough shaft would stick out (thats what she said?)
