Author Topic: Some doubts (nothing really important) about mame.ini and two setups  (Read 1180 times)
Stormrider
  • Last login:September 28, 2014, 11:01:54 am
In one of my computers, a core2duo with TFT, Nvidia card, etc. I have MAME setup with stretch in the monitor's native res and with an rgb effecto. This is part of my mame.ini
throttle                  1
syncrefresh               1
refreshspeed              0
video                     d3d
prescale                  1
waitvsync                 0
hwstretch                 1
filter                    1
resolution                1920x1080@60
triplebuffer              1
switchres                 0
I've read it's better to use tripple buffer rather than vsync. Is this right? Or should I set both on?
Contrary to syncrefresh, which synchronizes all games to the monitor refresh rate, I don't know exactly what's the result of activating refreshspeed. Performance is silk-smooth as I have it right now, so it's off.
I don't know what's switchres either. If I set it to on, the games run at maximum speed.
Another doubt I have is about multithreading. When enabled, the sound has issues. Is there any performance gain when activated? Oh, and do you recommend priority set to 1?
By the way, do you have hlsl working? 144 goes fine with hlsl and with the same ini, but 148 reports a direct3d error here.
And this is my setup in a different computer, a core2duo, also with XP, with a CRT low res monitor, ArcadeVGA and games running in native resolutions.
throttle                  1
syncrefresh               1
refreshspeed              0
video                     ddraw
prescale                  0
waitvsync                 0
hwstretch                 0
filter                    0
effect                    none
resolution                auto
triplebuffer              1
switchres                 0
Games run look and run perfectly smooth in low res, but I still have the same doubt about using vsync, triple buffer or both.
Thanx in advance.
