Author Topic: SOLVED: Kick not working in MAME 0147u1  (Read 5009 times)
cmoses
« on: October 29, 2012, 09:20:36 am »
Building a new cabinet and working on my MAME configuration.  I wanted to use the most recent version so originally I compiled 0147 and when I went to do some testing I was having problems with all the Midway games.  This was a problem that everyone was having I found out so I waited for the update. Once the update came out I downloaded the 0147u1.diff and recompiled my MAME.  I went in tried the Midway games and I was still having an issue.  The error I got was:
"The selected game is missing one or more required ROM or CHD images.  Please select a different game.  Press any key to continue".
I realized that they need the Namco bios/roms, so I added them in.  Now all of the Midway games seem to work (Dig Dug, Galaga, Pacman, Ms. Pacman, etc) except for Kick.  I am still getting the same error when I launch Kick.  I have tried the kick.zip and the kickc.zip and I get the same error as above.  Is there a additional bios/rom that is needed or is there a parent ROM (Pacman needs Puckman) or is still broken in the current version.
If anyone has any ideas or a solution please let me know.  If it is still broken, is there a place to let the MAME dev's know?
« Last Edit: October 29, 2012, 02:16:48 pm by cmoses »
Wade007
  • Last login:April 06, 2017, 01:33:35 pm
  • A MAME cabinet at home is heaven
    • bit.ly/1cWnoIC
    • Cheapskategamer.com
Re: Kick not working in MAME 0147u1
« Reply #1 on: October 29, 2012, 12:05:07 pm »
Could be that your Rom for Kick is outdated. Does it give you the exact same error as before or a list of missing Rom elements?
I'd try finding an updated Rom for Kick. :)
My Super Arcade cabinet project:
Software blog article: http://bit.ly/1cWnoIC
Hardware blog article: http://bit.ly/1dWxjvP
YouTube video: http://bit.ly/1N818Xm
Super Arcade Cabinet Progress thread (Now Complete):
http://forum.arcadecontrols.com/index.php/topic,123292.0.html
Frontend Video Intro: http://bit.ly/1P9HPDN
« Reply #2 on: October 29, 2012, 12:31:33 pm »
Romcenter has helped me a ton with versioning issues.  I suggest that you look into it. Alternatively  run mame from command line and it will tell you the missing rom.
cmoses
« Reply #3 on: October 29, 2012, 02:10:17 pm »
Thanks for the info about running MAME from the dos prompt. I didn't know it would display the missing rom.
As it turned out it was missing 82s123.12d which I found is in midisso.zip. I just copied it over from my ROMs drive and it works fine now.
rushkiss
  • Last login:May 29, 2013, 03:09:41 pm
Re: SOLVED: Kick not working in MAME 0147u1
« Reply #4 on: April 16, 2013, 08:55:38 am »
I am still having trouble with the Kick rom. I have mameplus.  I actually downloaded the  midisso.zip. file and placed it in the rom folder and also tried the general mame folder and still not working, any help, Thanks
« Last Edit: April 16, 2013, 01:57:39 pm by rushkiss »
