Author Topic: WTT my k7203 wells gardner for g07 chassis  (Read 1004 times)
omlifecrew
  • Last login:January 05, 2020, 12:46:50 am
« on: October 20, 2012, 10:18:01 pm »
Looking to trade my wells-gardner k7203 chassis for a g07 chassis.  Or offer it up as trade for repair of my g07 chassis.  See photos of my board (k7203). I haven't pulled out the broken neck from the neck board. I just had work done on it to replace caps and get it up and running.  Being clumsy, while reinstalling it, I snapped the neck off of my monitor.  :cry: I have no use for either anymore.
ed12
Re: WTT my k7203 wells gardner for g07 chassis
« Reply #1 on: October 20, 2012, 11:35:37 pm »
hi
ok i will byte
what is wrong with the g07 ?
cap kit/hot/hot-transformer/reg..all them part's are easy to get for under $125.00
olny thing u want to worrie about is the 30 old pix tube..? and if that is the case just go find a tube..there beening thrown out every day now,socket 19/23,swap yoke
and move on..if u are not tech..then have a shop do it for u
about $87.00 if u provide part's
or swap out to lcd..again there cheap enough now day's
ed
omlifecrew
« Reply #2 on: October 22, 2012, 08:13:06 pm »
My g07 takes a few minutes to warm up.  Once screen shows up about half the top of the screen is covered in black.   A few minutes later the screen is perfect except for the far right side of the screen which looks like it bends.  There is also 1 line almost all the way at the right of the screen that runs down the screen.  I also have an untested g07 board that I bought with the k7203 and both tubes.  I was hoping to swap the working k7203 chassis and now accidently broken monitor. I was also hoping to buy a cap kit, width coil, hot, etc. and replace parts in the donor board.  Thought both the g07 and k7203 chassis would be worth a trade to repair my almost failing chassis in my current ms. pac man unit.
