Author Topic: NeoGeo PCB JAMMA?  (Read 1257 times)
pointdablame
NeoGeo PCB JAMMA?
« on: October 11, 2003, 12:07:24 pm »
I'm really considering turning my second machine into a NeoGeo since I love pretty much every NeoGeo game ever, lol
My question is: Is the NeoGeo PCB a JAMMA standard board, or is it something entirely different? I searched the 'net a bit and some just say its the MVS system, one said it was JAMMA, etc etc. I figured you guys would have a definite answer. I'm almost positive that it IS, I just want to make sure.
I'm just wondering if I'm lucky enough to just buy a NeoGeo board and some carts and plug it into my JAMMA cab, or if it's going to be more complicated than that.
« Last Edit: October 11, 2003, 12:08:50 pm by pointdablame »
first off your and idiot
Cisco Kid
Re:NeoGeo PCB JAMMA?
« Reply #1 on: October 11, 2003, 03:03:44 pm »
yes its JAMMA compatible
just plug it into your harness and you should be good to go  ;D
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #2 on: October 11, 2003, 03:07:16 pm »
Not true...they are somewhat different:
http://www.hardmvs.com/manuals/Jamma2NeoGeo4SlotPinout.pdf
Most of the big important pinouts are the same, but the overall harness pinouts are not exactly the same.
question_answer
  • Last login:June 24, 2007, 11:38:44 am
« Reply #3 on: October 11, 2003, 06:51:17 pm »
All the one slot motherboards are full JAMMA standard.
Two, Four and Six slot mobos are MVS (Multi Video System) standard pinout.
The soundchip on the multi slot boards can be damaged over time when used with a JAMMA harness.
Cisco Kid
« Reply #4 on: October 11, 2003, 07:21:17 pm »
... and just how exactly would the harness damage the sound chip?
question_answer
« Reply #5 on: October 12, 2003, 02:26:07 pm »
MVS pinout is stereo and the JAMMA harness is mono, the soundchip gets damaged because of the incorrect wiring - some pins need switching.
The guys in Tech Support over at Neo-Geo.com/forums will be able to give the complete reasons, but be assured the sound will go bad.
