Lightguns Arcade1Up --- Bug Reports --- Site News
Author Topic: New DWJ skin from LHUPATECH: "LHUPATECH Yongsan WS Lite ART"  (Read 4777 times)
LHUPA
  • Last login:September 03, 2019, 01:05:09 am
« on: February 17, 2012, 03:08:09 pm »
There's a new skin from LHUPATECH available in three different versions! It's called "LHUPATECH Yongsan WS Lite" that refers to Yongsan: a district of Seoul, Korea. The full version of the skin will still unavailable until the DW Jukebox software limitations been fixed... That's why here ther's the 3 "Lite" versions available! On this page, that's the "ART" painted (2nd) version! See full description below!
PRESENTATION OF THE DW JUKEBOX SKIN PROJECT
The present skin comes from an inspiration of a futuristic korean landscape found over the Internet that has made this project
possible! The landscape "from way out" of Yongsan Gu or simply "Yongsan" looks truly like a new found planet! The first skin project
built on this subject, used animated floating selecting panels or "indexes", specific diplay fonts and transparency in the imaging.
But, due to the limitations of the DW Jukebox software at this time, the original project has been replaced by three "lite" versions
(described below) until these limitations will be fixed. The skin also features an "hideaway front panel" that looks like a jukebox
plexiglass front panel! The three "Lite" versions available are: the genuine enhanced pictural version, the "ART" painted version
and the adaptation of the original "glowing edges" version that gives a truly "electric" design! All "Lite" versions look like the
"full" version with all features except that they use pictural effects instead the real transparency and animation effects. That's
the seventh DW Jukebox wide screen skin by LHUPATECH!... Enjoy!
FEATURES OF THE "LHUPATECH YONGSAN WS LITE" SKIN
 - Wide screen
 - Pictural design from an official region of the World
 - Transparent "floating" effect "Art-Deco" selecting panel design
 - Uses the DW Jukebox built-in screensaver as "hideaway front panel" feature
 - Realistic engineered sound effects with timers
 - Two part skin for use as pictural or solid color (for easy selecting panel reading)
 - Available in three versions
A SIGHT IN THE FUTURE OF YONGSAN, DISTRICT OF SEOUL, KOREA!
The new skin from LHUPATECH subjects and depicts a futuristic korean landscape (District of Seoul so called "Yongsan Gu" or simply
"Yongsan") where's featuring either a truly futuristic geometric building especially built of glass that consists on the "Administrative
District Office".
SOUND EFFECTS USED FOR THE SKIN PROJECT
So, all the sound effects were built according to the sounds of such modern "chariot" mechanism
jukeboxes sometimes with beep sounds of "touch tone" panel keyboard buttons! The "LHUPATECH Yongsan
WS Lite" skin features "all-electronic" beep sounds on all buttons including the invalid
button selecting alarm. The mechanism scan and record play sound effect features a "clean-cut"
with no "scratches" record begining with a clear "pop" as the tone arm touches the surface of a
"brand new" record! All mechanism sound effects are engineered closiest as possible to a real jukebox
mechanism to get the best virtual jukebox experience possible!... LHUPATECH hopes that you'll love it!
CREDITS
Special thanks to HoundDog63 for the bright idea to build 16-9 (wide screen) skins for DW Jukebox! Either,
LHUPATECH (Me), would like to thank him for the use of his wide screen DW Jukebox skin templates in my wide screen projects!
Special thanks to Ben Nathan (Ben Nathan Fonts) for the use of his free .ttf font so called "BN Defect"(or simply "defect"): a particular
"pictural", "rectangular" or "square" font that matches perfectly the present LHUPATECH's DW Jukebox skin "LHUPATECH Yongsan WS Lite" to
be redistributed all over the Internet troughout the official dwjukebox website or other dedicated websites as BYOAC. This will avoid any
possible copyright concerns about fonts in that skin! A particular thank you to Chris La Mantia for the creation of DW Jukebox... the
extraordinary free software wich is closer to a real jukebox with numerous cool advantages as the possibility to skin it easily with
no creativity bundaries!
I hope you'll like it!
LHUPA
« Last Edit: February 19, 2012, 11:30:45 pm by LHUPA »
