Ok, its been a while since ive updated this thread, so have made a fair bit of progress, am now about 90% complete, and just need to wait for the artwork and install windows etc.
After reading in chriz's build thread, about how he used a usb hub, i thought id follow suit, will make it alot easier to upload new tables and update to the cab using the SD slot...
Backbox painted white inside and speaker/DMD panel fitted...
I shall be using the logitech speakers, seeing as the 2.1 system cost me over £100 theres no way i was going to not use them, and cut the ends of for car speakers. Got my glue gun out, and make sure they werent going anywhere...
Removed the metal frame from the 32" LCD backbox screen, and sprayed them black just to make sure you couldnt see any hint of them when all fitted together...
Black frames fitted back onto the LCD, and LCD inserted in backbox...
Plexiglass and wooden bezel fitted to backbox, these are held in place via 2 PVC 'U' channel strips at the top and bottom. Chrome T-Molding added, will be keeping the protective film on the molding until my artwork is fitted, as dont want them getting damaged!....
Refurded some leaf switches from a gutted batman cab i picked up last week, as good as new
Coindoor switch assembly wired up, thanks for jukedock for helping me out with the wiring...
Switch assembly fitted to coin door, also added microswitch to the door, so when you press the 'coin eject' button on the front of the door it activates the microswitches, will be using these as credit buttons....
All buttons wired up, tried to make it as tidy as possible. And man did it take ages, who would have thought it would take over a day, thank god for cable ties!!!. On a side note will have to swap out the LED-Wiz for an I-PAC, as there isnt enough inputs on the LED-Wiz
PC fitted inside the cab, minus my 40GB SSD HD that turned up today!!.....
A full shot how it stands at the moment, well i actually have the PF LCD installed now also....
A close up of the backbox, damn its hard to keep the screen clean, shows up every mark and spec of dust
I added a microswitch near the coindoor, so when you open the coin door it releases the microswitch thus activating it, ill use this as the 'Coin door open' button....
As many members have done, im using a microswtich for the plunger atm, until a better option appears, i have heard alot of memebrs talking about 'bounce back' though im not 100% sure what they mean???
USB and SD reader HUB installed, and also the logitech's volume panel installed, so i can change the volume without too much hassle...
Fitted the power and reset buttons for the PC, though im having slight problems with the power switch. For some reason when i turn the PC on, it powers up but then a few seconds later powers down, i have tired a normal PC power switch and this works without any issues, so i dont know what the problem is???...
And a final shot of the front of the cab...
Hopefully will have the tables up and running by the weekend, so i can start enjoying my creation!!
