Author Topic: MAME: Save cpu overclock settings or create cheat  (Read 9256 times)
Konrad
  • Last login:April 07, 2022, 05:29:27 pm
« on: August 08, 2011, 04:55:46 pm »
I love the games Double Dragon 1 and Double Dragon 2, but I can't stand the slowdowns. I see two solutions for the slowdowns, which I tried to research with no result.
1. Slider controls
Here you can overclock the cpus. The values aren't saved though :(. Do I have to enable an option, or is there a diff file ?
2. Create a cheat
I guess this should also be possible. My problem is that I have the option to enable or disable cheats, but not to create one. Isn't that part of the official releases ? Do I need another build ?
I'm currently using MAME 0.141. I do know how to compile my own version and add diffs to the source. Any help is appreciated.
  • Last login:December 05, 2025, 11:03:36 pm
Re: MAME: Save cpu overclock settings or create cheat
« Reply #1 on: August 08, 2011, 06:04:53 pm »
Google crusin usa overclock and you should find info on creating a cheat file for overclocking the cpu.
Konrad
« Reply #2 on: August 09, 2011, 05:30:14 pm »
Searching "cruisin usa overclock" doensn't give return a useful link for me. Care to post the link ;) ?
If you mean this link:
http://members.shaw.ca/kelvsyc/cheatguide.html
I don't have the option "Add/Edit a New Cheat" in the official build.
Konrad
« Reply #3 on: August 12, 2011, 12:48:56 pm »
Hm. No one creating cheat.dat's anymore :( ?
peteski
« Reply #4 on: December 01, 2013, 04:17:05 am »
Hi there,
I was just looking for the same thing. I looked through the cruising USA post but it seemed too complicated for me. Since that post is almost 10 years old I was just hoping there might have peen a nicer solution.
I have found bits and pieces around on the web but nothing very conclusive.
Any ideas?
Thanks,
Pete
Haze
    • MAME Development Blog
« Reply #5 on: December 01, 2013, 12:08:27 pm »
The slowdowns in DD1/2 (especially 2) should be significantly less in a current version (0.151) anyway due to new information fwiw..  (just incase anybody finds this in Google when looking for information about DD slowdowns)
The official cheats page / forum is still http://cheat.retrogames.com/  They have a forum where you can ask whatever you want about the cheat engine or specific cheats.
The current cheat system (unfortuantely) uses only the debugger to create / find cheats rather than the easier to use internal interface of the past so those old guides won't work, no.
« Last Edit: December 01, 2013, 12:19:14 pm by Haze »
peteski
« Reply #6 on: December 01, 2013, 04:50:34 pm »
Great thanks Haze, I'll check that out. Yeah I found so many dd posts while I was looking around :) makes sense though, it plays so much better boosted up.
