Author Topic: help ID'ing wires on encoder for mouse hack pls  (Read 2265 times)
vintagegamer
  • Last login:October 26, 2025, 06:07:31 pm
  • Seasoned Arcade Survivor.
« on: April 16, 2011, 04:35:36 pm »
Please see the 2 attached pic of the existing encoder PCB from my Sega Monaco GP cockpit.
On the pic showing the back, the order of the wires goes: 1. white (far left), orange (2nd wire), blue (3rd wire), and yellow/red (4th wire).
After reviewing the board, I believe that wire 1 (white) is common/ground, wire 2 (orange) is one of the sensor wires (goes to IC1 on the front of the board), wire 3 is the other sensor wire (goes to IC1 on the front of the board also), and wire 4 is the +5.
My questions are as follows:
1.Can anyone confirm or deny my current thoughts on the 4 wires?
2. if my guesses are correct, where on the mouse PCB do I wire the +5 and the ground/common wires to?
I checked the original manual for this game but the schematics are crap unless you have your PHD in Electrical Engineering and Metaphysics.  :(
Thanks for any help!
VG
vintagegamer
Re: help ID'ing wires on encoder for mouse hack pls
« Reply #1 on: April 16, 2011, 07:40:21 pm »
Found the below site so I'm going to use it as a guide and hopefully give this wire-up a test tonight.  Stay tuned.
http://www.jstookey.com/arcade/720/720-arcadejoy.php
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #2 on: April 17, 2011, 10:59:21 am »
From the front view of the board you have, those 74xxxx chips all have the same pwr pins. Looking at them with the little notch cutout facing up, the top R corner will be +5v and the lower L corner is gnd.
Clean those optos while you have it out....they don't like to work well with a good layer of dirt...
dramaone
  • Last login:February 24, 2018, 03:48:53 pm
« Reply #3 on: December 12, 2016, 01:42:55 pm »
can you confirm the id of wires on this opto board?
thanks in advance
ed12
« Reply #4 on: December 12, 2016, 02:03:20 pm »
the plus rail runs on the top of the pcb
the - or ground rail runs along the bottom (solder side)
it is clear as a bell in your first picture (top side) u can see where pin 14 goes for the ic's
on the bottm u can see the big trace going around 3/4's of the board = ground
ed
dramaone
« Reply #5 on: December 12, 2016, 02:14:17 pm »
Thanks, I dragged an older thread plus my understanding electronics are piss poor. :)
dramaone
« Reply #6 on: December 12, 2016, 03:06:10 pm »
ed
Sorry, I'm sure your explanation is clear but I still don't get it.
Please help a dunce.
Is wire 1 ( white wire ) plus or negative?
Thanks again
« Last Edit: December 14, 2016, 03:02:02 am by dramaone »
dramaone
« Reply #7 on: December 14, 2016, 03:25:29 am »
Thanks again
