Author Topic: Entry Cleanup... Volunteers needed!  (Read 13472 times)
  • Last login:July 02, 2026, 07:26:12 pm
« on: March 25, 2011, 05:08:07 am »
I've been mucking around with the current entries and the db is in need of a cleanup.
By that I mean many entries are outdated on the mame end of things..... broken inputs have been moved or fixed, inaccurate control types have been fixed, hacks have been removed ect....
The db will undergo major changes in the future, so now would be a perfect time to give everyting a once over.
When viewing entries on the site by controls, the MISC section is the place to look at.  Generally if anything is odd, it's given a misc label.
Re: Entry Cleanup... Volunteers needed!
« Reply #1 on: March 25, 2011, 06:08:30 pm »
This is a list for my own benefit, there are some things that have to be fixed on the server end, so I have to make a note of them
bladestl - the original entry had a trackball as the input type because at the time version E (the version that used a trackball) was the parent.  Now version T, which uses a joystick, is parent rom.  Two trackball-centric entries need to be made for the clones bladestll and bladeste
frogs - fixed joystick, which is now correct in mame.
sarge - the joystick hack was removed, so I updated misc details to reflect this
topspeed - driver is still garbage but now it is different garbage than the current entry... perhaps I can clean it up and submit it myself?
vindicator - removed mention of a input hack in the misc details as that has been removed.
720 - added in all the  new controls as best I could.  Note... controls viewers and the dat now have to worry about port tags, which were previously unused for anything important.  In 720 two different cfg values can be given for the same spinner due to this.
aburner2 - useless button removed, so I updated the entry... ditto for balloon fight
barricad - game now uses a 8way joystick for the buttons...... this constant isn't in the db
« Last Edit: March 25, 2011, 08:29:33 pm by Howard_Casto »
« Reply #2 on: March 25, 2011, 07:10:15 pm »
*oops*
« Last Edit: March 25, 2011, 08:03:29 pm by Howard_Casto »
