Author Topic: Tech: G05 802 XY monitor - darn lines and no contrast  (Read 1399 times)
OTTOgd
  • Last login:September 08, 2025, 06:37:17 pm
« on: September 28, 2010, 06:54:02 pm »
The monitor on my Asteroids was actually fine and playable aside from occasional jitters/jaggies before I installed a cap kit. At first power on it seemed to blaze too brightly with 'spider legs' but then I turned it off and back on and now it is dim with 'spider legs' with brightness set to full and the contrast pot doesn't seem to do anything? Maybe just a new contrast pot?
Any other ideas?
Thanks for looking.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Tech: G05 802 XY monitor - darn lines and no contrast
« Reply #1 on: September 28, 2010, 10:08:31 pm »
the few i've seen were plauged with cold solder joints .
inspect and resolder anything questionable .
test - still no go ,
then check the following :
r518 470k
r515 3.3k
r513 220
q503,504  MPSU03
q502 2N3906
also verify the 90 volt souce  P500 pin 1
schematic here: http://technical-department.servegame.com/monitor_schematic_diagrams/electrohome/G05-802.pdf
OTTOgd
« Reply #2 on: October 07, 2010, 10:04:10 am »
Thanks a lot for the great info, qrz! I'll post an update when I'm up and running.
