Author Topic: fe3darcade - 640x480 possible?  (Read 1439 times)
PkingRoch
  • Last login:June 08, 2020, 02:12:47 pm
  • This is supposed to be fun...
    • Paul & Brian's Arcade Adventure
« on: August 01, 2003, 02:04:35 pm »
This is my next FE try.  Looks coo and all, but I can't seem to set it up on my cab.  The problem I'm having is that the cab can only display 640x480 and I haven't found an option for the FE to display in only that mode.
Is this possible, and if it is, how do you set it up?
AlanS17
    • AlanS17
Re:fe3darcade - 640x480 possible?
« Reply #1 on: August 01, 2003, 02:11:45 pm »
The trick isn't in changing the resolution in the FE. First you open it up in configuration mode while your desktop resolution is 1024X768. Then in your configuration in the frontend options, look for "resize" and set it to "true". This will make the FE match your desktop resolution. Now all you have to do is change your desktop resolution to 640X480 and... TADA!
However, fonts don't always appear as nicely so things may get a bit more difficult to read. After all, it was designed with 1024X768 in mind. Good luck.
PkingRoch
« Reply #2 on: August 01, 2003, 02:24:36 pm »
TADA - is right.  Thanks!
