Author Topic: yobo "gunman" with wingun not seeing it?  (Read 2211 times)
oisuxx
  • Last login:June 05, 2010, 04:25:04 pm
« on: May 09, 2010, 07:22:26 pm »
so i have a ems topgun II and the thing is garbage. i dont like it at all... so that was money wasted. so i got these yobo guns thinking it would work with wingun, but i cant get them to be recognized. what i DO notice is that when i plug them in they want to be associated with the topgun again. how do i stop this? is there a driver that i use? i pointed it to the wingun folder and it started to find stuff, then it told me to find the topgun.ini to complete it. has anyone has success with these yobo guns and wingun? if so can you plese help me out?
thanks in advance!
Dannymh
  • Last login:December 23, 2011, 05:09:54 pm
Re: yobo "gunman" with wingun not seeing it?
« Reply #1 on: May 09, 2010, 08:20:18 pm »
May I ask what you dont like about the topguns?
I got mine, and despite the distance issue I actually really like the gun itself. I added a wide angle lense (you can do this by buying a peephole from the hardware store and using the lense from that, should cost you about $5, this will give you far better distance from the monitor and worth trying if distance was your only issue)
TBH I had nothing by trouble with wingun.
As for topgun you are going to have to remove any trace of these drivers, do this via device manager
oisuxx
« Reply #2 on: May 11, 2010, 08:24:02 pm »
the tracking was waaaaay off. i think its because my monitor is at a slant though. i just couldnt get it to work properly.
