Main => Main Forum => Topic started by: madgammer on June 22, 2007, 08:01:48 pm
I just got a MK3 dedicated cab and noticed that it had a little burn in from the credits. I was looking at it during the day and outside so it was a bit more obvious then outside or at night. Is there any way to decrease the burn in or fix the monitor? I don't think it would be too bad once it's in a darker room, but if it can be fixed or adjusted even better.
Worse case scenerio how hard is it to replace the monitors on those cabs?
Put tinted plexi, tinted glass or sunshielded plexi over it and you will never see the burn.
