Main => Main Forum => Topic started by: jimmer on February 12, 2018, 09:42:53 am
I'm looking for some help or advice from electronics guys.
Q1: What's with all the components on the happ pcb? Is it just signal conditioning? Using a pro-micro as encoder, I get the same result with just 2 optosensors and 1 resistor to limit the current to the emitters*
Q2: What would be a rough cost for pcb manufacture. Qty 100, 40mm x25mm. With holes for 2 optosensors, 1 resistor, and a 4 pin header. I haven't tried to work out how many layers are needed.
Q3. How much to design the pcb for me and send me the files to order it ?
Q4. Also I need help to choose a suitable opto sensor (eg small 12mmx5mm like the Happ) the ones I used before are larger and I didn't choose them.
*actually that was on a big tempest optical wheel, I haven't tried it on a small trackball opto wheel.
Some time ago, I designed a spinner with electronics. Maybe you find some usefull informations:
https://www.thingiverse.com/thing:2021152 (https://www.thingiverse.com/thing:2021152)
https://youtu.be/xyOA1leHPJQ (https://youtu.be/xyOA1leHPJQ)
https://hackaday.com/2017/01/23/awesome-illuminated-arcade-spinner/#more-240635 (https://hackaday.com/2017/01/23/awesome-illuminated-arcade-spinner/#more-240635)
I did find it very useful, thanks. I bought those ITR9608 and added your arduino interrupt routines into my HID encoder :)
I found a small sensor with similar specs so will try that http://www.farnell.com/datasheets/1829985.pdf? (http://www.farnell.com/datasheets/1829985.pdf?) I'll test the simple circuit and then work out how to get the boards made.
