Software Support => GroovyMAME => Topic started by: Spardaradra on March 14, 2018, 06:05:21 am
Hi guys, finally i was able to install CRTEmudriver on clean XP 64 install, but i wanted to take a try and flash my 4350 with atom15. I followed each step, saving bios, flashing bios (with AtiWinFlash), then i rebooted my computer...and voila, 15hz bios sequence, 15hz Windows logo....then, black screen.
I really dont understand why. Here's my setup
CPU : I3-3225
MB : Asrock B75 Pro3-M
4GB RAM
64Go Sandisk SSD
HD4350
J-Pac (set on 15hz only)
Everything plugged on my Egret 2
Any help.would be great, thank you
Use the other output.
Thank you, i'll try tonight after work
I'm plugged on the DVI output actually (with DVI--VGA adaptee), i will try VGA output tonight
yeah if you have native vga on the card, there's absolutely no reason to try using the DVI->VGA dongle
The ribboned VGA-ports, those not on the card PCB itself but connected by flat ribbon cable, are often subject to video noise. If you have a choice, the/a port on the PCB is better.
EDIT: card from the 6000 series and up obviously only have one analog output, so you don't always have a choice :)
Many thanks to all of you and especially to Calamity for such a great work, now its working like a charm now on VGA output
