Main => Forum/Website Discussion => Topic started by: tommyinajar on March 01, 2021, 01:46:13 pm
I like to post a questiion-then look for an answer. Every GOOD forum has this button, why not here ?
Then I spotted this-finally
(https://i.imgur.com/ScUiPVz.png?1)
Whys it cut off?
Whys it cut off?
Check the zoom on your browser.
- If I increase the zoom to 150% or larger, the same thing happens on Firefox.
There are two useful options on the toolbar under the list of forums.
- "New replies" brings up a list of every thread you've posted in with posts that you haven't read.
- "Unread posts" brings up a list of all threads with posts that you haven't read.
The only drawback to those two options is that they don't catch edits since you last read that thread.
You can often spot those by going to the main list of forums. http://forum.arcadecontrols.com/index.php (http://forum.arcadecontrols.com/index.php)
- If you've read everything in a sub-forum, you'll see a black diamond.
- If there are posts you haven't read (or edits since you last read that thread) in a sub-forum, you'll see a blue diamond.
Whys it cut off?
This also happens if you use larger fonts.
So for once, it WAS me! :lol
