Front End Support => Maximus Arcade => Topic started by: matjr72 on December 29, 2016, 12:33:07 pm
I'm running Maximus v2.10 with MAME v0.167. How do I disable the game warnings that require you to type "OK" or move the joystick, left then right, to accept. I read in another forum that you can modify the MAME .ini file to disable. I have done that and they no longer appear IF I launch MAME without the use of the Maximus FE. When I use Maximus, the warnings still appear. Help!
Is MA launching Mame using the same exe that you are using outside of MAME --- might be that MA is launching the non patched mame.exe instead of the no-nag patched exe
