Main => Artwork => Topic started by: Dizydawg on February 01, 2021, 11:29:47 pm
Sorry for asking such a newbie question, but I had a pdf template given to me. I already started to make my bartop arcade but need some artwork. So how do I add artwortwork to a pdf or how do l create a psd file from a pdf?
That depends on the software you are using.
Look for tutorials on YouTube about importing/converting a PDF using your software and you'll want to learn about layers so you can keep your bartop outline on a different layer than the artwork.
You may also want to check out Frostillicus' vector shape creation tutorial.
http://www.arcadecontrols.com/files/Miscellaneous/VectorTutorial_v1_2.zip (http://www.arcadecontrols.com/files/Miscellaneous/VectorTutorial_v1_2.zip)
