Update:What version was this fixed in?
The problem is resolved in the next version of Mamehooker, thanks to Howard Casto (...and his patience ;)). Thanks also to Andy from Ultimarc for his assistance.
I have the same issue using Mamehooker 5.1
Did you ever get your issue resolved @Headrush69?No. I cannot get MameHooker to see my iPac Ultimate. (USB ID:D209:0410)
Hello @Headrush69 and @Moleburt. My I-Pac Ultimate is also not being detected by Mamehooker 5.1. Do either of you have a link to the version that fixes this issue? I cannot find anything...
Edit: Thank you Headrush69! The modified mamehooker.exe and PacDrive32.dll solved the problem for me.
Edit: Thanks Moleburt. With that updated MameHooker it is working.
Hello. I have the same problem. I have two I-pac Ultimate. I tried to light up some leds, but mamehooker tells me that there is no Ultimarc device. It works fine with Ledblinky.Did you ever get your issue resolved @Headrush69?No. I cannot get MameHooker to see my iPac Ultimate. (USB ID:D209:0410)
Hello Kierdo,
I have added a link to my last post.
Mamehooker works, but there are some problems. I have two ipad ultimate boards and a servo stick control board from ultimarc. Due to servostick, the second ipad board works as board3 and not board2. When you click on the Show supported device in mamehooker, the boards are not located, but they work in the test menu and games. The saddest thing is, after exiting mamehooker, the dll error error 6 appears and after the program sometimes does not work correctly. Has anyone faced such problems?
I am looking for the modified version as well. Can someone share it?
i am in search of the modified version also. Can someone send me a link?
thanks
Mine is not working. I downloaded the last version from creator's web and no luck.
It does not show compatible devices and also is not working in test menu (tested every ID). Could you send me the modified version?
Many thanks in advance!
