Main => Audio/Jukebox/MP3 Forum => Topic started by: dom on October 29, 2018, 12:10:55 pm
hi my name is dom
from mtl canada
need help a friend of mine found a old rowe ami diplomat 1965 everything works ok but when selecting either a or b selections everything seems to work except the actual playing of the 45 's starting from a0 to b9
all the other letters work meaning c to the end
please help
thanks
Hello Dom,
It sounds as if there is a keyboard fault.
When you select A0 what happens?
Regards
Alan Hood
ami-man
UK
Hi Alan
thks for the response
when i select a 0 or b1 etc up
you see the selecter spins but does not pick up the 45
but when you select for example c2 it picks up the 45 and plays
Hello Dom,
Before you check out the keyboard, inspect the Search Unit PCB for any sign of cracks in the tracks, if there are any more than likely they would be on the side where the long connector from the keyboard plugs into it.
If your wiring is the older type that plugs into the top of the search unit rather than on the side (later jukeboxes) to make sure that all the connections are good, meter back to the keyboard if nessary.
If all looks and tests out OK try cleaning the keyboard switches on the effected letters/numbers, my guess it is the letters that are the trouble. You can use alchol in the pubs I used to use Gin and a small brush or you could use tape head cleaner. Do not use any form of switch cleaner, it will not work and may leave a residue.
Please us know how you get on.
Regards
Alan
Alan Hood
ami-man
UK
