Main => Driving & Racing Cabinets => Topic started by: ignignot on March 22, 2019, 11:46:01 am
Hey Gang - i have a cab with the immersion touch sense wheel in it and it works pretty well in windows 7 - the pedals dont work(they jitter constantly, and arent hooked up) but the wheel works great.
I upgraded to a faster PC but i had to install windows 10 on it.... i reinstalled the same driver i was using and the wheel works the same but as soon as the feedback motor kicks in it cuts out and stops responding completely.
anyone run into this problem before? if thers no fix... what is the best setup for getting my whole rig working like an x360 controller (pedals, wheel, AND FFB)? I have a logitech driving force pro I can hack but id rather go with the cleanest solution that will let me use this big-ass motor that I already have.
thanks BYOAC
Cracked it!
I was using a usb hub and a 15' extension cable - removing the board from the hub and plugging in directly fixed my issue. Win 10 + immersion driver is good to go.
Hello I came across ur post about using windows 10 and ive been trying to get this to work on my global vr nascar cabinet i wanted to change out the orginal pc and install mine with windows 10 and keep the same steering wheels and pedals could you help me out and point me in the right direction ? i was also wondering what driver u were using
thank you
http://forum.arcadecontrols.com/index.php?topic=135310.0
All info+driver is in this thread
thank you
