Arcade Collecting => Miscellaneous Arcade Talk => Topic started by: Ixliam on December 26, 2004, 12:04:34 am
Anyone have any information on building your own skee-ball machine ? I've seen a few off-brand ones with basic digital counters for scoring. Wondered if anyone had attempted this in any form.
Brad
I was just about to start the same thread! I for one am highly interested in this!
Someone else was looking into this on KLOV.com, and essentially it is MUCH more expensive to build one than it is to buy one.
I really wouldn't think it would be too difficult. I'm not talking about being an exact replica, but a basic model with a 10' track, and 50/40/30/20/10 scoring.
The curved part that throws the ball up could be built by curving thin plywood (old medieval technique). What you do is take layers of thin plywood, soak with water (making it flexible). Using this heavy duty wood glue (used for boatbuilding) glue the two parts together and nail/screw to a form. For the form, build like some mini-steps out of 1x2's, 2x4, etc on another piece of plywood scrap. Nail one part of the plywood to the flat base, the other section to the steps to give it the curve. The wood will flex being wet, and the glue will set, keeping that curve.
The other option would be to build the steps/angled part from wood, and make the curve with bondo. Probably much easier and quicker. The ball return could be a simple piece of large cheap PVC cut in half right below the holes, then running down to the bottom where a small square box to hold the balls would be.
Scoring could be done with either some type of simple circuit or a custom program running on an old crappy machine, like a 286. You wouldn't need much horsepower to do it.
The rings where the balls hit could be made from a sheet of plastic or old juice/food barrels. Use a heatgun to shape.
(http://users.adelphia.net/~sdberner/skeeball.jpg)
Just a thought...
Brad
someone posted a BYO skeet ball a while back...I don't know if they ever got done with it or not........
this might help:
http://forum.arcadecontrols.com/index.php/topic,19796.0.html
I have a Skeeball machine which I bought and fixed up for a total of $600. Sometimes the local arcade auctions have these machines for even cheaper.
Check out all the pictures of my SkeeBall machine at my website.....
http://unclet.arcadecontrols.com
Here is one pic:
I was just wanting to suggest metal to make the curved area. It seems like it would be a lot eaiser to do than the bondo or the plywood.
Here's some Skee-Ball wiring on sale on Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=13718&item=6141871082&rd=1
I've been digging around on this for a few days and I think I'm going to give it a shot. I have access to some interesting materials that end up as scrap at the office, and I have a circuit for the scoring mechanism.
The circuit will run a 7 segment LED. Looking at how they score on a 3 digit display, the first digit (right side) is always 0. You then use this circuit to display the tens and hundreds. Just attach another circuit for the hundreds and tie in the reset to a start button.
http://www.aaroncake.net/circuits/counter.htm
You could then have it trip some type of bell/whistle when you put a ball in the right hole, maybe a flashing light when you hit 450.
As far as making one, I have scrap thin white plastic that can be curved into the target rings, and I will probably do they same with the curved ramp. I haven't decided on how I want the ball return to work.
You could go with the original look, and have it spit the balls into the chute. Or you could decide that this is for home use, and just have it spit it to a collection box of some sort at the end of the ramp. Another option would be to run a tube under the right side, have it feed the balls from there.
Ball-wise, I found wooden 3" balls online from wood shops. I ordered 10 of them @ $35, so I will let you know how they work out.
Not sure who here might be interested in this and is in Georgia, but your welcome to contact me if you want to assist in anything, or stand around and laugh.
Brad
Has anyone taken measurements of one of these things yet?
I've been waiting for this too! Somebody please take a tape measure to one of these things :)
Also, does anyone know what the rings are made out of? I have a funny feeling they are from a custom/expensive material. They are pretty soft, almost a white rubber. I'd expect a harder material to be rough on the balls/gameplay.
want to save money? just use pipes as rings for the smaller ones!
The circular white tubes are actually made by GoodYear especially for SkeeBall Inc. They are basically white walled tires ... except that the "white wall" completely surrounds the rubber. The circle is held together by metal and screws.
The "brown-ish" or "tan-ish" carpet located on the rolling surface (and also behind the target holes) is actually a cork board which is made overseas and imported especially for SkeeBall Inc. Last time I looked you could buy brand new cork "carpet" from SkeeBall Inc. for around $150. You simply put your adhesive glue down (contact cement ... not sure??) and roll out the carpet and then use a roller with pressure for good adhesion.
If you are interested in seeing what the inside of a classic SkeeBall machine looks like, then you can check out the pictures of my machine at my site:
I still believe you would appreciate a real classic SkeeBall machine rather than building your own. You can get them from between $400 and $800 if you call you local dealers and see what they have (assuming you pick it up yourself). You can even find cheaper ones at auctions some times..... Of course, if building one gives you a great sense of fullfillment, then I would be wrong :)
I would just think the final feel, play and look would not compare to a real classic. Just my two cents.
If you are going to go through with this, then let me know if you need any help.
For those in New Hamshire, I saw this in a Yahoo Group. Too bad it is 1200 miles from me.
---- Quote ----
Hey Folks, A friend of mine is selling some Skee-ball lanes. They are Skee-Ball Model H, which are the yellow and red lanes with the large digital numbers. All of them are complete and worked when removed form the Salem Willows Arcade last week. $400 each and must be picked up in Pelham NH. Anyone interested call Tom, (603) 635-7495
---- Quote ----
Before I get 100% started, I am going to try to locate one locally. If I managed to get one, I would replace the ticket dispenser with a LED counter so that instead of tickets, it would just run a digital counter. Least at this point I will have the parts for it.
Brad
I think you are a wise man .....
Thanks for the dimensions, too bad I'm having better luck here than actually find a machine that's not around $2200. That's the only ones I have found nearby. Georgia seems to be empty when it comes to any sort of arcade goodies.
I have drawn up basic cad plans based on a sketch I did and the dimensions you have. Looks like for the basic frame it would take two sheets of wood. That would cover the sides and the ball box/ticket holder, along with the bottom support. That does not include the ramp. So guessing, 3 sheets of 4x8 would do it, along with the 1x2/2x4s for a support frame. Seems to me about as much there as for an arcade cabinet, there is just not anyone actually building these things as a hobbyists.
Course, I would still love to find one nearby in the SE US. The ones I've found fall into either the TOO FAR AWAY category, or TOO EXPENSIVE category.
If anyone has Autocad or access to it, or can view DXF files, I can send you what I have so far.
Brad
Where are you located in Georgia (?)
I'm in Austell. If you like, contact me off-list at ixliam <$AT$> com**REMOVETHIS**cast }}dot{{ net.
Sorry for the crazy email format above, but you know how spammers are.
Brad
Guess I could just send you a PM in this forum instead .......
Seems like there should be plenty of SkeeBall machines in a big city like Atlanta.
The plastic I have is pretty flexible, I can bend/twist it with one hand, and it takes a good beating. Plus, its free. I actually just walked back to where our shop is and they have more scrap back there, so I will probably at least try to make the target area so I can get those pieces cut out (they will cut them for me on nice pro equipment that we use to build tradeshow exhibits). I did see some cork flooring online but didn't go any further than google-ing it. It came in 2'x3' sheets, probably for tackboards. But something absorbant might not be a bad idea.
I don't have any kids so no need to worry about someone chunking a ball at it. This is mostly for me and my wife, and the occasional visit from parents/in-laws/brother. If I wanted to go the cheap way, Sears has a Harvard Roll-Ball thing that is on sale for $179. It looks like the picture I posted above of the Skee-Ball looking thing.
Brad
Just be careful is you use real corkboard, since a big wooden ball will dent that as well ..... just would not want you to go through all the work of building and then discover your rolling surface is all dented up.
PS: You have been outbid
What is the height on the rubber targets ? I'm guessing 3.5-4" just looking at the pictures.
What am I outbid on, that empty display on e-bay ??
On that display, I know the older ones used lights behind a fake LED looking scoring unit. Any idea what kind of light holder fit in there. I'm really torn between getting an original display and putting incandescent lights in it, or going modern and using a large LED. Price-wise, its about the same. 3-5" LED for the main score, and 1-2.3" LED display for the balls rolled counter.
Brad
Rubber target height is 4"
Yes I saw you were outbid on the SkeeBall score display thing.
What do you mean light holder? Do you mean light bulbs?
It looks like from the light holder that a bulb in some sort of fitting goes in with a twist type of connector, similar to how some cars bulbs go in tail lights (least on my Toyota Corolla they do since I access them from the trunk). I'd guess it has a plastic bulb holder with two plastic flanges coming off it with a rubber/foam gasket to act as a seal and to put pressure on the connection to keep it from wiggling loose.
Glad I was outbid on that thing. I saw where it has those grey scratches/chunks out of it. With the rate it is going at, I could go with an modern large LED display and not have to worry with the bulbs. Only addition to my circuit would be a darlington driver chip so that the output from the CMOS lines would switch the 9 volt supply to the LED segment, since the ones I am looking at pull more power since each segment had 4 LED's behind it according to the specs on the display. Even if I went with the bulbs and used small wattage 12 volt bulbs, it would still need the darlington to switch. Not sure what skee-balls had at one time in them to turn on the displays, but trying to use relays would be too slow, whereas transistor switching is much faster.
Brad
Can you give me the dimensions from the top down to the ramp every 1' as I have below ? This is my estimate.
(http://wotlmud.home.comcast.net/skee2.JPG)
Here is my marque I did.
(http://wotlmud.home.comcast.net/skee1.JPG)
I picked up an 2'x8' roll of cork from a local hobby store. Once a ramp is made I will be able to test it out. From what I gathered online, there is cork flooring available, some as underlayers used. If the cork in that use can take people walking over it, I'm sure it could handle a 1lb ball rolling along..
Brad
Brad
I will try to post something tomorrow for you .......
Here are some more measurements ...... hope this clarifies some stuff.
That really helps a great deal. I did find some skee balls in Indiana, but they want $1000 working as-is, or $1600 if the fellow cleans it up to like-new condition.
There are two in Texas on e-bay now, a 10' and a 13' model. The 10' is already up past $500. I cut out the ramp today, I am doing it with heavy lexan (more scrap from the office). I will have more support braces under the ramp, enough so you could walk across the ramp if you wanted to (but don't plan on it). I will be making it out of 3/4" MDF, which I have yet to purchase in the no-so-likely hope that someone will suddenly offer me one at a reasonable (aka cheap) price. I'm willing to drive to get it, but not 1100 miles one-way (which is where the cheapest one is so far). If you flew up there, rented a truck, then drove back, you are already pushing the price up to the $1000 mark, not counting blowing vacation time at home.
At this point I'm ready just to build one for not only the experience and gratification of saying "I built my own skeeball", but also since there is a good amount of interest I can document how it can be done. Your help in getting info and measurements has been invaluable, and I greatly appreciate it.
Brad
Good luck .... let me know whether you need anything else.
I saw where that was coming and plan on being there, hopefully I can grab some of the cheapies, maybe even a skeeball.
We used to play skeeball when I was about 7-15 when we went to Panama City, FL. I guess that would be about 1975-1983. There was a skeeball place on the boardwalk that was 10 cents a game. My dad would save all his dimes and misc other change for a year, and we used that money to go down there at night and play. At the end of the vacation, we would play our last games on the night before we left, and my parents would divide the tickets between my brother and I. Then we would buy silly junk like rubber snakes, chinese finger cuffs, spider rings, and other silly prizes you got.
The machines we played on were a bit older than the one we are dimensioning, and didn't have the 100 rings. I'm not planning on putting them on mine at the present time. The marque was a bit simpler, and I did find a few pics of them on the net. The scorboard case wasn't as narrow as yours is where the net connects, the angle from the scoreboard just runs straght down to connect with the angle where the target sits, which for me seems much sturdier, so that is how I am going with it. They also just had a simple coin slot right below where the balls came out, and the ticket printer was another simple slot on the front of the left steel piece. There was an orange light on the top of those pieces indicating you had credits. Course this is all from memories and what I saw in the pictures.
Brad
Hmm, this looks very interesting. and it looks fairly simple (easier than cutting out an entire arcade cab) also the electronics would be very simple. The one problem is getting the ramp correct. not the straight part but the curve... I fear if it didn't have the right curve it would never feel right (or you'd get used to it and bomb on a 'real' machine)
I would still worry about the type of material you chose for the target chutes since the wooden balls really smack into things when the come flying off the curved ramp.
PS: At my arcade site you can see what the inside of the SkeeBall machine looks like (with the target area taken off.....)
btw, someones selling new ones on ebay for 300 bucks. This seems WAY to low to me. Are these crap?
The $300 table you are referring to is the same model (white) as the one pictured near the beginning of this thread.
To answer your question .... I would believe it depends on the person's taste I guess. Personally, I would believe these games would not give a person the true SkeeBall experience as they get from the machines they use to play growing up in the arcades.
PS: If you can fit a 13' SkeeBall table in your house, etc... then these size tables tend to be less money than the 10' ones, since they are an older model and also take up more room in an arcade than the 10' ones. It seemed to me (when hunting for my SkeeBall machine) that the more room a vendor can save on the arcade floor the better, thus the lower price for the bigger ones.
I'm with Unclet on the skee-ball issue with the cheapo ones. The ramp is just a straight plastic board with probably a 30-45 degree part that launches the ball. It doesn't look like a skee-ball, even though you are still putting balls in the holes. Its just like with the arcades, you could play MAME with a gamepad, or you can build an arcade cabinet for the real 'feel' of the game. All depends on what you want to do.
I want my skeeball to look and feel like the real version, and I'm willing to probably be the first one to actually build one and document it for others to do as well.
I've thought about being able to take a mold of the curve somehow the digitize that with cad. If anyone wants to grab some playdough, clay and saran wrap, they could take a mold, let it harden, then trace the curve on a piece of paper, please do. Mail it to me and I will put the curve into cad.
For me, I'm not worried about going to an arcade somewhere and playing a skee-ball machine. The only place near me is Dave & Busters that has skeeball, and most of those are the new fancy ones which don't hold the same appeal as the old style ones. I don't play arcade games outside of my MAME machine at home unless they are something really interesting (like the gun/fishing/firefighting ones). I have no desire to collect tickets to earn some cheapo prize, so if my curve initially isn't exact, its ok. I think it will be close enough, and I will try to get some measurements on that as well.
Since the subject came up, Unclet could you take measurements of the curve every inch down to where it becomes the flat ramp ? That might help. I plan on trying to heat-form lexan to get the curve, but if that is not successful then I may have to build a mold and use bondo. Could even take a heavy board (like 1-2" thick) and cut multiple sections out of it, then glue together to form the 19" wide curved section. I think there are more ways to do this than people realize. The wood cut would be easier I believe, and can't believe I didn't think of it earlier. You woulc just cut out S shaped pieces out of wood then glue them all together, sand smooth and mount. A good scroll or bandsaw would make this easy.
I am starting on the project this weekend, so I will try to get a website up with some pics, or at least put it in the project announcement section.
Brad
Well I am going to look at some of these skee ball mesurements and start thinking about it. I will most likely have to wait and see how you handle the curve, but it sounds like it wont be much of a problem. good luck to you.
I really think you should think this through more. I have seen these for sale working for $300 before. A friend of mine bought one that is in NEAR mint condition (I really mean it!) for $600. When these things are sold, they sell CHEAP because they are so large, not many people have the room for them even if they wanted one.
You would EASILY have that much in materials, and it still wouldn't look like a real one, and you wouldn't have the sounds and bells and whistles that a real one would have. Building a MAME makes a lot of sense because it can play so many games and takes up little space, but building a Skee ball just doesn't make sense.
Just be patient, and you WILL find one locally for a decent price. It sounds like you have to get one RIGHT NOW. Well if you build one, it will probably take far longer than waiting until you find a real one, and that is assuming you finish (it would be easy not to finish a project this large).
I'm all about people being creative, building things for themselves, etc. but building a skeeball just doesn't make much sense if you are thinking logically.
Wade
Wade: I have been trying to talk him out of it as well .... but I think he views it as a challenge, so it might just be fun to build for the hell of it. I bought mind for $500 and then spent an additional $100 for renting a truck (plus gas) for hauling it home as well as cleaning supplies and some minor new parts, paint, etc.... Total is $600 and it looks great.
Ixliam: I was already out trying to figure how to take a measurement of the curve this morning...... give me some time to think on this one and I will try to come up with something. My kid is sick, so bare with me .... :-[
First off I don't see it as that complicated a project, no more so than a full size arcade cab. (depending on how the curve of the ramp is, of course) and sometime we want to build something simply for the joy of building it :)
I actually want to build the thing and document it. The whole counting circuit to handle scoring/ball counting is only about $20 in parts. Not very much if you ask me. Sound effects, add in a computer or use something else, take your pick. The old ones I played on just had a bell that rang, nothing special.
It also helps to have access to the right tools and materials, and for instance, I cut the yellow plastic top to go over where the balls sit today at the office. Total cost - $0. Now that's me. My father is also runs a welding shop, so I have access to metal fabrication equipment to make the metal front. Stainless is pretty expensive to use there, aluminum is not, but you do have to watch bending aluminum too much. That overall curve is not bad. Try to crank it 90 degrees and it will likely shear on you.
I would almost bet the first person to build an arcade cabinet from scratch got responses about cost and time, but sometimes you just want what you want. Someone has to be that person to make that step, and since I already have the material, the electronics, and the plans already set out, the project is a go. I will make these drawings/plans available to anyone who wants them, should they chose to build one as well. But, I would also say that I do have access to things many people may not, and in their case certain corners may have to be cut. But like all things, even MAME cabinets, there are those who want an copy, and those who want to customize. I tend to fall more towards the "copy" side of it.
In any case, whenever you get those measurements would be fine Unclet. I hope your kid is gets to feeling better, and I do appreciate all the help you have been. The pics of the insides of it are very helpful.
Brad
Honestly, I don't think building one of these would be that difficult.
Looking at unclet's pictures, the overall construction is painfully simple, and there doesn't seem to be anything particularly complicated.
The worst part would be the ramp, and replicating the metal coin/ticket dispenser covers.
I imagine instead of screwing with the large LED displays, you could replace them with a small flatscreen monitor, and just use a simple piece of software to keep score and make the appropriate noises.
go for it.........can't wait to see the documentation of it and the work in progress........keep us posted on how it's going......
good luck
I say go with the LED display for authenticity also i'm sure you can find some kind of electronic buzzer/bell to go off at the appropiate time...
Its not even a real LED, and I have purchased an original skee-ball Model H score and ball count cover. What it looks like is a red plastic front, then molded plastic hollow sections that a lightbulb goes in. When you score, it turns the various bulbs on. Though it looks like an LED, it is actually not one. Price-wise for me, the cost was within $2 of each other. I decided to go with the original bulb style instead of modernizing it with a 5" 7 segment LED. The circuit I have will work for either one, just have to make sure you get the +/- correct on the LED or else you will smoke it. With bulbs, it doesn't matter.
Bending metal, even stiff metal is not difficult. Easy way without much equipment is to put it over something round, and bend it. I used to be involved in medieval reenactment, and we made our own armor from 14 and 16 gauge steel. Its not too difficult, you just have to work with it to get the hang of it. But putting a curve in a flat piece is easy. I figure if I can make gorgets, articulated knee and elbow armor, I can probably curve some metal plate. Look up how to make roman lorica and you can probably find some information on metal working with simple tools as far as doing the curves.
I've got the large side panels of the scoring section cut already, along with the scoring rings and top panels for the ball chute.
Brad
My kid is sleeping now .... and was actually starting to feel better (crossing my fingers and wishing for a sleepful night)........
Ok, here is what I have for you. I cut this wooden shape twice (based on a construction paper cutout I did earlier) and this was the best one. There is obviously a gap at the bottom. The center of the gap should have an extra 1/4" added on and the outer parts of the gap should have an 1/8" added (I labelled these areas)..... I think it is self-explanatory. I do not think this will be a big deal since the overall shape of the curve is pretty much well documented for you and also the ends of the wooden shape I cut out are flush on the rolling surface. Basically, you should be able to eye ball the level-ness of the rolling surface while using the wooden shape even though the gap exists ..... did that make sense (or am I rambling).
Also, I took other various digital pictures of the wooden shape while it was on my SkeeBall machine so I can email those to you instead of posting them all here. Basically, close ups and different angles.....
If you think this will help you out, then email me your shipping address and I can ship it out on Monday (if I can find a box to pack it in nicely).
my email ==> emailAddrRemoved
I have a better one for you, and much easier. Lay it down on the floor with a ruler up top. Then take a closeup picture of it. Make sure it is straight down so you get a nice overhead shot. With that, I can pull it into AutoCAD and trace it exactly as you have it. You can e-mail the pic full size directly to me at ixlaim@comcast.**REMOVETHIS**net. I did that with an online side-shot of a skeeball machine and your measurments you sent me were within 1/16" of what I had.
Brad
Ok, I sent you three fullsize pictures....with a ruler.
I attached two of the pictures (at a reduced size) below so you can see what is coming....
Good Luck
My emails are getting rejected ..... even an email which I simply had text (ie: no file attachments..) ...... although I did get your email.
Anyway, I noticed the email you sent me was from a different email address (ie: starting with a 'w') ..... I will retry sending the pics to you again using this new email address..... Let me know if you get anything soon.
Got it, and that works out great. Most of the major pieces are cut out now. I'm going to try to get the major pieces cut out tonight, then start putting them together tomorrow. Do know one thing, I will sleep good tonight!
Brad
If your interested, my Autocad 2000 DWG file, a DWF (viewable with free Autocad DWF viewer), Unclet's pics along with a good pit of other pics I found I have put on my website at *** FILE REMOVED ***.
All the major parts are now cut out save for the top of the scoreboard part, and the target board. I'll post pics of the progress tomorrow.
Brad
Your link doesn't work. ???
I didn't notice I had used my space up on the other account.
Brad
I'm going to move this over to the project section now.
Moved to:
http://forum.arcadecontrols.com/index.php/topic,29727.0.html
Brad
If anyone has any questions on my project or the skeeball construction in general, please feel free to ask. I thought I would unlock this again just to keep the discussion on general skeeball things going now that the project is moving along well.
(http://ixliam.home.comcast.net/sk72.JPG)
Brad
Hi:
I'm new to the group.
I operate an old arcade in Pennsylvania. I have over 60 vintage machines with a few early Skee-balls in it. They are completely mechanical from 50's and 60's.
I'm looking for a part called a "Quad Gear". It's probably the most frequently replaced part on these old machines... because they took a lot of abuse and were made out of junky metal.
It's located in the scoring unit and it controls the rotation of the score when game is reset. A few teeth break on it almost always in the same spot. I know..I have several broken quad gears with identical missing teeth. When that happens, the scoring unit will not stop at zero when reset.
It the grand scheme of things, not an important thing in life. But I'd like to find some replacements maybe sitting around somewhere and fix the machine correctly. Skee-Ball, Inc. does not have. Believe me, I've tried.
Can someone help?
Thanks,
Jimmy Rosen
Old Sled Works
Duncannon, PA
717-834-9333
www.sledworks.com (http://www.sledworks.com)
I had a similar problem with a part from my shuffle alley. had to pay a machine shop to make me 2, but better than having it broken. I guess you've tried that too?
Art
Have a pic of one?
Try to get a part number from SkeeBall Inc. then contact www.betson.com since they usually store old SkeeBall parts.
If you end up needing one made, might try some of the hobbyist clock builders. Those folks make all kinds of gears and such, and you may find someone local that could crank it out for you... maybe for the price of a 6 pack.
Brad
i have been following the progress of the skee ball build and i have started to plan every thing out and i was looking through the plans i have and i just relized that i have no dimensions for the ball ramp. does anyone have those dimensions for me? thanks
You might have better luck asking on another thread, this one was over 4 years old.
