Main => Buy/Sell/Trade - non-retail => Topic started by: opt2not on June 29, 2020, 10:43:52 pm
Found one. Thanks.
I’m looking for the grey fat 360 Power supply for the white 360 versions (not slim).
If anyone has a spare, let me know.
There’s like 3 different versions, you need to figure out what wattage you need. Compare the power port on your console with pictures online.
If you aren’t scared, you can cut the plastic key pins out of the plug and use a low wattage supply on a machine that needs a higher wattage one. It’ll probably run a little hot but I’ve done it and it was fine.
Ah, looks like I need the Falcon PSU.
The one that does 12V, 14.2A and 5V, 1A
Xenon/Zephyr will also work without modification.
