1 | 3/8 inch Bore Clamping Hub | $7.99 | ServoCity |
1 | 3/8 inch x2 inch Precision Shaft | $1.39 | ServoCity |
1 | 3/8 inch Servo Shaft Coupler (Hitec) | $12.99 | ServoCity |
2 | 3/8" Bore, Face Thru-Hole Pillow Block | $25.96 | ServoCity |
1 | Standard Servo Plate A | $4.99 | ServoCity |
2 | Side Tapped Pattern Mount A | $9.98 | ServoCity |
1 | Shafting and Tubing Spacers (12 pack), 0.375” bore | $1.69 | ServoCity |
1 | 6-32 Zinc-Plated Pan Head Phillips Machine Screws (16), 1/2in | $1.28 | ServoCity, Home Depot |
1 | Hitec 645MG servo | $29.99 | Hobbytown, Amazon, ServoCity |
4 | #6-32 Phillips head machine screws, 1.5” length | $1.18 | Home Depot |
1 | 6-32 nuts (30 pack) | $7.64 | Home Depot |
8 | 1” washers with 3/16" bore | $2.36 | Home Depot |
4 | ¼” washers with 3/16" bore | $0.98 | Home Depot |
1 | Monoprice 200X200mm Bracket Universal Adapter | $16.36 | Amazon |
4 | VESA screws | $4.39 | Amazon |
1 | 3/4 in. Neodymium Rare-Earth Magnet Discs (3 per Pack) | $3.98 | Home Depot |
2 | 1" galvanized corner brace | $3.44 | Home Depot |
2 | Vinyl bumpers, 1/4" (they come in the assorted pack) | $4.16 | Home Depot |
1 | Micro Maestro 6-Channel USB Servo Controller (Assembled) | $19.95 | Pololu |
1 | 6V, 3A Power Supply | $24.99 | ServoCity |
1 | 2.5x5.5mm Female DC Power Jack / Male Battery Lead Adaptor | $7.99 | ServoCity |
| TOTAL | $193.68 | (plus shipping) |
