Front End Support => Maximus Arcade => Tutorials => Topic started by: GameTech on September 06, 2010, 10:13:41 pm
I just got the entire mame .139 set, and was curious if there is a way to "verify" the roms, etc.. I think clrmamepro is a program that does this? I just wanted to make sure the entire set was really a .139 and has all the correct rom names, etc, before I continue with a large cabinet build.
Thanks guys.
ClrMAME is the way to do it. I believe you need to have a MAME.dat file for the current version you are using. The dat file contains all the info CLrMAME needs and then it cross checks your roms. :-)
You can find the dat files here:
http://www.logiqx.com/Dats/ (http://www.logiqx.com/Dats/)
D
Thanks Delus, I will check this out.
I agree with Delusional, ClrMamePro is the way to go.
But it can be confusing when you first start using it, this may help:
http://retro-roms.blogspot.com/2010/01/clrmamepro-tutorial-part-3.html (http://retro-roms.blogspot.com/2010/01/clrmamepro-tutorial-part-3.html)
How do you upgrade the 0.136 set to 0.139 standard? (is there much difference?) or do you not bother?
