Main => Software Forum => Topic started by: sgeist28 on June 04, 2017, 11:55:24 am
How do I permanently save the ppjoy.ini settings in the oracle vbox vm? Each time I relaunch the game the ppjoy settings default back?
Sorry for posting to wrong thread.
I set up the vbox and figured out how to adjust the mouse sensitivity by lowering the ppjoy thresholds.
However when I shut down the computer down it doesn't seem to be reading the ini file even though I've saved the changes using ppjoy.ini as the file name.
Any suggestions?
Off the top of my head, you need to add the path to ppjoy.ini as a command line parameter. I remember I had a hard time setting it up, too.
I will give that a try thanks!
